ReplicatorG Skeinforge settings not changing October 07, 2011 12:07AM |
Re: ReplicatorG Skeinforge settings not changing October 07, 2011 12:22AM |
They are easy to edit and are laid out the same as in the skeinforge.Quote
Relicat.org
Profile Location
Skeinforge profiles are located in various locations, the ones shipped with ReplicatorG can be found in:
replicatorg/skein_engines/skeinforge-[VER]/skeinforge_application/profiles
replicatorg/skein_engines/skeinforge-[VER]/skeinforge_application/profiles-experimental
Duplicated profiles are saved to your home directory and will show up between different versions of ReplicatorG. This location varies depending on your operating system:
Windows - /Users/[USERNAME]/.replicatorg/sf_[VER]_profiles/
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: ReplicatorG Skeinforge settings not changing October 07, 2011 10:07AM |
Re: ReplicatorG Skeinforge settings not changing October 18, 2011 02:01AM |
