Arduino Uno Electronics February 17, 2012 06:55PM |
Re: Arduino Uno Electronics February 18, 2012 05:30AM |
1. Does anyone know the minimum memory requirements for reprap firmware?
2. What are the minimum number of pins I can get away with?
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Arduino Uno Electronics February 18, 2012 05:48PM |
Re: Arduino Uno Electronics February 18, 2012 06:09PM |
Re: Arduino Uno Electronics February 19, 2012 01:33PM |
Re: Arduino Uno Electronics March 02, 2012 12:39PM |
Re: Arduino Uno Electronics March 05, 2012 06:17PM |
Re: Arduino Uno Electronics March 06, 2012 03:29AM |
Re: Arduino Uno Electronics March 06, 2012 03:24PM |
Re: Arduino Uno Electronics March 06, 2012 04:27PM |
Re: Arduino Uno Electronics March 06, 2012 07:25PM |
Re: Arduino Uno Electronics March 22, 2012 01:54AM |
Re: Arduino Uno Electronics March 22, 2012 06:47AM |
so what happens when a stepper is enabled all the time?
Re: Arduino Uno Electronics June 17, 2013 11:42PM |
Re: Arduino Uno Electronics August 11, 2013 11:51AM |
Re: Arduino Uno Electronics August 12, 2013 05:09AM |
Re: Arduino Uno Electronics August 12, 2013 07:22AM |
Re: Arduino Uno Electronics August 12, 2013 08:00AM |
Re: Arduino Uno Electronics August 13, 2013 07:07AM |
Has anyone tested, could it be possible to combine Z motor direction signal to any of the zy or extruder motor direction signal? From signal point of view that should be possible, because z motor is never stepped during x or y movement anyway - or is it?
Re: Arduino Uno Electronics August 14, 2013 06:26PM |
mikropehmo
Re: Arduino Uno Electronics January 15, 2014 05:12AM |
Re: Arduino Uno Electronics February 04, 2014 12:02PM |
fgascon
Thanks for the advice.
I guess that if you have min endstops and configure the size of the RepRap's printable area, then the software should know the max. I will put my enables all on the same pin has you said.
I won't need to chain my endstops, because I now have enough pins for everything. But if choose to add other stuff in the future I'll definitely look into it.
So my pins mapping would now look like this:
0 serial
1 serial
2 Z_DIR
3 Z_STEP
4 Z_MIN
5 X_STEP
6 HEATER
7 PS_ON
8 E_DIR
9 E_STEP
10 X_MIN
11 Y_STEP
12 X_DIR
13 STEPPER_ENABLE (bonus: the arduino led will give feedback about the enable state)
A0 THERMISTOR
A1 Y_DIR
A2 Y_MIN
A3
A4
A5
