CP210x-based USB-TTL converter for Gen7 electronics February 26, 2012 05:58PM |
Re: CP210x-based USB-TTL converter for Gen7 electronics February 27, 2012 03:45AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: CP210x-based USB-TTL converter for Gen7 electronics February 27, 2012 01:49PM |
Re: CP210x-based USB-TTL converter for Gen7 electronics February 27, 2012 07:05PM |
Re: CP210x-based USB-TTL converter for Gen7 electronics February 28, 2012 03:41PM |
Re: CP210x-based USB-TTL converter for Gen7 electronics February 29, 2012 06:25AM |
I actually programmed the bootloader on a breadboard with an 8MHz crystal. Could this have caused the problem?
Re: CP210x-based USB-TTL converter for Gen7 electronics March 02, 2012 03:04PM |
Re: CP210x-based USB-TTL converter for Gen7 electronics March 03, 2012 05:46AM |
I plan to try the FiveD firmware
Re: CP210x-based USB-TTL converter for Gen7 electronics March 05, 2012 04:15AM |
Traumflug
FiveD is pretty old and I'm not sure wether it's 20 MHz-compatible.
Re: CP210x-based USB-TTL converter for Gen7 electronics March 05, 2012 10:14AM |
The reason I ask is because the PSU is not coming out of standby.
Re: CP210x-based USB-TTL converter for Gen7 electronics March 05, 2012 01:49PM |
Traumflug
What makes you expect the PSU should turn on?
settemp plaor
move x 100in pronsole and nothing happens (unless I physically short the necessary pin - in which case the heater but not the motors turn on).
Re: CP210x-based USB-TTL converter for Gen7 electronics March 05, 2012 07:40PM |
settemp pla move x 100Is this a Pronterface special? I'm not aware of such commands. About all RepRap firmwares, including Teacup, speak G-code: [reprap.org]
G1 X100 F200
M104 S150
Aly
Re: CP210x-based USB-TTL converter for Gen7 electronics March 14, 2012 08:55AM |
Aly
Re: CP210x-based USB-TTL converter for Gen7 electronics March 14, 2012 09:32AM |
Re: CP210x-based USB-TTL converter for Gen7 electronics March 14, 2012 07:20PM |
Re: CP210x-based USB-TTL converter for Gen7 electronics March 15, 2012 01:12PM |
Legot
I have a CP2102 converter working with my Gen7 and freeduino, with auto reset.
The reason auto reset does not work for you is that it requires a low value capacitor (<1uf) between the DTR pin and the reset pin on the Gen7, so that it pulls down the value properly.
Re: CP210x-based USB-TTL converter for Gen7 electronics March 15, 2012 04:52PM |
Re: CP210x-based USB-TTL converter for Gen7 electronics March 15, 2012 08:11PM |
It worked - firmware uploading at least. Being able to at least upload firmware without having to use the programmer is a big improvement. I still haven't got the motors operating with any of the firmwares, but that's a separate issue.Quote
dslc
I'll get back to you as soon as I try this.
Re: CP210x-based USB-TTL converter for Gen7 electronics March 15, 2012 08:43PM |
Aly
Re: CP210x-based USB-TTL converter for Gen7 electronics March 16, 2012 05:05AM |
Re: CP210x-based USB-TTL converter for Gen7 electronics March 16, 2012 11:42AM |
Aly
Re: CP210x-based USB-TTL converter for Gen7 electronics March 17, 2012 05:13PM |
Re: CP210x-based USB-TTL converter for Gen7 electronics March 17, 2012 07:13PM |
Re: CP210x-based USB-TTL converter for Gen7 electronics March 17, 2012 07:35PM |
terramir
David I think we are aving the same issue here because you could upload the firmware and now your stuck can you verify that you can actually connect to the host program your using because I cannot at this time
Aly
Re: CP210x-based USB-TTL converter for Gen7 electronics March 18, 2012 07:05AM |
Re: CP210x-based USB-TTL converter for Gen7 electronics March 19, 2012 10:52AM |
CP2102 problem April 05, 2012 09:04PM |
Aly
Re: CP210x-based USB-TTL converter for Gen7 electronics April 08, 2012 06:28AM |
Re: CP2102 problem April 09, 2012 12:59AM |
