Gen 6 board, no extruder movement April 28, 2012 07:33PM |
Re: Gen 6 board, no extruder movement April 30, 2012 04:53PM |
Re: Gen 6 board, no extruder movement May 01, 2012 05:23AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Gen 6 board, no extruder movement May 01, 2012 06:33PM |
Re: Gen 6 board, no extruder movement May 02, 2012 05:56AM |
Re: Gen 6 board, no extruder movement May 02, 2012 10:57PM |
Re: Gen 6 board, no extruder movement May 03, 2012 07:07AM |
Re: Gen 6 board, no extruder movement May 03, 2012 07:12PM |
Re: Gen 6 board, no extruder movement May 04, 2012 04:42PM |
Re: Gen 6 board, no extruder movement May 05, 2012 07:31AM |
Re: Gen 6 board, no extruder movement May 06, 2012 12:41AM |
In file included from /analog.h:15, from analog.c:1: /config.h:33:3: error: #error GEN6 has a 644P! set your cpu type in Makefile! In file included from /temp.h:4, from analog.c:7: /config.h:33:3: error: #error GEN6 has a 644P! set your cpu type in Makefile! In file included from /temp.h:18, from analog.c:7: /config.h:33:3: error: #error GEN6 has a 644P! set your cpu type in Makefile! In file included from analog.c:23: /config.h:33:3: error: #error GEN6 has a 644P! set your cpu type in Makefile! In file included from analog.c:23: config.h:282: error: 'PINA5' undeclared here (not in a function)
Re: Gen 6 board, no extruder movement May 06, 2012 08:12AM |
Re: Gen 6 board, no extruder movement May 07, 2012 10:45PM |
Re: Gen 6 board, no extruder movement May 08, 2012 08:23AM |
Re: Gen 6 board, no extruder movement May 08, 2012 08:08PM |
Printer is now online. echo:Marlin: 1.0.0 RC1 echo:Configuration.h: 2012-02-25 | Author: erik echo:Free Memory:1606 PlannerBufferBytes:1168 echo:Using Default settings: echo: Steps per unit: echo: M92 X40.05 Y40.05 Z3360.00 E75.00 echo:Maximum feedrates (mm/s): echo: M203 X500.00 Y500.00 Z5.00 E45.00 echo:Maximum Acceleration (mm/s2): echo: M201 X9000 Y9000 Z100 E10000 echo:Acceleration: S=acceleration, T=retract acceleration echo: M204 S3000.00 T3000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 echo: PID settings: echo: M301 P63.00 I2.25 D440.00 Error: : Extruder switched off. MINTEMP triggered ! Error: Printer halted. kill() called !!
Re: Gen 6 board, no extruder movement May 09, 2012 01:54AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Gen 6 board, no extruder movement May 09, 2012 09:23PM |
Re: Gen 6 board, no extruder movement May 17, 2012 07:02PM |
