Using the cheap 101-5433-EV Mountain Switch encoder July 30, 2008 03:06AM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder... July 30, 2008 03:57AM |
Admin Registered: 17 years ago Posts: 1,915 |
Re: Using the cheap 101-5433-EV Mountain Switch encoder... July 30, 2008 09:31AM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder July 30, 2008 10:02PM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 06, 2008 01:16AM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 06, 2008 11:17AM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 06, 2008 06:27PM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 07, 2008 07:22AM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 07, 2008 11:34AM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 07, 2008 01:52PM |
Sure, but a stepper/stepper driver combo is usually more expensive than a cheap DC gearmotor/DC driver/encoder.
AFAIK there still isn't a less expensive solution to run them than the RRRF board which is $28.
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 07, 2008 03:05PM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 07, 2008 11:30PM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 08, 2008 12:30AM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 08, 2008 05:12AM |
With more precise positioning, we can create more precise geartrains, which can have less backlash
This isn't necessarily true. Since they cost less, you can use more powerful motors (think about it, a $25 DC motor...)
I'm guessing you forgot about the $25-each stepper motors [store.rrrf.org]?
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 08, 2008 06:07AM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 08, 2008 04:16PM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 08, 2008 04:33PM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 08, 2008 04:47PM |
Nop has made progress with quality, so I don't think this is a valid statement anymore
You can apply brakes. You can make it lighter. There are probably more options.
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 08, 2008 05:02PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 08, 2008 06:15PM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 08, 2008 06:35PM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 10, 2008 07:14PM |
Re: Using the cheap 101-5433-EV Mountain Switch encoder August 10, 2008 11:21PM |
