Bootloader installed?
Posted by msandersmay10
February 20, 2013 08:38PM
I was wondering if there's a way to check if your bootloader has been installed? I'm having troubles with installing the firmware and want to backtrack to confirm whether the usbasp correctly installed the bootloader.
thanks
msandersmay10
Re: Bootloader installed?
February 22, 2013 07:23AM
Upload a firmware doing something visible. If that works, you can assume uploading the bootloader works as well.
And yes, if you have a programmer, you can upload the entire firmware with that, too. Bootloaders are for those _without_ programming device.
