Re: Firmware to drive X-Y galvanometer June 03, 2014 07:15AM |
Admin Registered: 16 years ago Posts: 13,906 |
Re: Firmware to drive X-Y galvanometer June 08, 2014 11:08PM |
Re: Firmware to drive X-Y galvanometer June 09, 2014 12:11PM |
Re: Firmware to drive X-Y galvanometer July 09, 2014 07:37PM |
Re: Firmware to drive X-Y galvanometer July 10, 2014 01:29PM |
Re: Firmware to drive X-Y galvanometer July 28, 2014 10:08PM |
Re: Firmware to drive X-Y galvanometer July 29, 2014 02:33AM |
Re: Firmware to drive X-Y galvanometer August 02, 2014 04:07AM |
Re: Firmware to drive X-Y galvanometer August 02, 2014 06:02PM |
Re: Firmware to drive X-Y galvanometer November 23, 2014 01:43PM |
Re: Firmware to drive X-Y galvanometer November 23, 2014 04:53PM |
Re: Firmware to drive X-Y galvanometer January 10, 2015 11:13AM |
Re: Firmware to drive X-Y galvanometer January 10, 2015 04:33PM |
Re: Firmware to drive X-Y galvanometer January 11, 2015 07:27AM |
Re: Firmware to drive X-Y galvanometer January 11, 2015 07:31AM |
Re: Firmware to drive X-Y galvanometer January 11, 2015 07:37AM |
i'm going to use at sla printer, so is the laser strong enough to cure the uv resin using a fast galvo?Quote
geniouskotaro
hey vicktorrrr
cna i use 405nm 20mw blue laser [www.ebay.com]
at this? [www.ebay.com]
Re: Firmware to drive X-Y galvanometer January 11, 2015 02:44PM |
Re: Firmware to drive X-Y galvanometer April 05, 2015 12:38PM |
Re: Firmware to drive X-Y galvanometer July 09, 2015 02:03PM |
VDX
... the galvo-head is OK, but the mirrors are designed for CO2-laser wavelength -- which laser do you have?
You'll need a high-speed analogue driver with up to 16Bit resoultion, what's not possible with an Arduino ... I'm using a dedicated driver for ILDA lasershows, but you can find proper electronics for this scanners at the manufacturers site too.
My PC-software is BeamConstruct with a self-programmed driver (here you'll need a programming license for 500€) ... check, if you can find a driver already installed in BeamConstruct, this would be the best way ...
Re: Firmware to drive X-Y galvanometer July 09, 2015 03:38PM |
Re: Firmware to drive X-Y galvanometer July 16, 2015 08:30PM |
Re: Firmware to drive X-Y galvanometer July 17, 2015 04:13AM |
Re: Firmware to drive X-Y galvanometer October 03, 2016 06:25AM |
Re: Firmware to drive X-Y galvanometer October 03, 2016 03:49PM |
Re: Firmware to drive X-Y galvanometer October 04, 2016 03:28PM |
Re: Firmware to drive X-Y galvanometer October 04, 2016 04:05PM |
Re: Firmware to drive X-Y galvanometer October 04, 2016 04:14PM |
Re: Firmware to drive X-Y galvanometer October 04, 2016 05:07PM |
Re: Firmware to drive X-Y galvanometer February 28, 2017 05:28PM |
Re: Firmware to drive X-Y galvanometer February 28, 2017 07:32PM |
