4pi and Nema 17
June 22, 2013 11:19AM
I've just recieved my 4pi board to use on a personnal 3d printer.
And i've to make some tests, the first one, was to connect to board to my pc...make it recognized...programm it....After it done (not so easy), i've connected a nema17 stepper, a battery (12V) lunch the interface, connect it to the board...
Up to here, every thing is good, then I tried to move the stepper, it made some noise, vibration, and the driver became VERY hot in 1 ou 2 seconds.
I've changed the current limit (in the init_configuration.h file), then re-make it, re-programm the board, that is no longer detected, you have to put a wire between two pins...but nothing better happen.
If someone has any idea, or link (it's not easy to find some documentation )
Thx,
Re: 4pi and Nema 17
June 22, 2013 11:42AM
Ok, sorry, connecting problem....
But always a problem when deconnecting/reconnecting the board, i've to reprogram it each time/
Re: 4pi and Nema 17
June 22, 2013 11:56AM
Have you tried changing the current on the board? motor calibration
Re: 4pi and Nema 17
June 23, 2013 07:32AM
> motor calibration
The principles described there are valid, but it is worth nothing that the 4pi does not have trimpots, it uses software controlled digipots instead.
Based on a quick look at the firmware it appears there is a Gcode command to set the current limit :
 M906 - Set motor current (mA) (M906 X1000 Y1000 Z1000 E1000 B1000) or set all (M906 S1000)
I don't know if there is a way to make the setting non-volatile, or if you have to set it every power on.
I'm not quite convinced of software current limit control yet, trimpots may be limited but they are quite simple.
Re: 4pi and Nema 17
June 23, 2013 08:17AM
Now it's ok,
It was a mistake in motor connecting.
The current limit can be non volatile (when re-programming the board) in the init-configuration.h file.
About the non-detection I've change this line in the main.c file:
PIO_InitializeInterrupts(0);
It was comment, so I un-comment it, and it's works fine now.
Just a little mechanics to do before having it ops.
thx
Re: 4pi and Nema 17
June 23, 2013 12:25PM
sorry. i really have not any idea about it.
