MatchboxARM August 02, 2013 03:53PM |
Re: MatchboxARM August 02, 2013 10:56PM |
Re: MatchboxARM August 03, 2013 08:46AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: MatchboxARM August 03, 2013 09:29AM |
Re: MatchboxARM August 05, 2013 05:22PM |
Re: MatchboxARM August 05, 2013 06:51PM |
Re: MatchboxARM August 06, 2013 06:11AM |
Re: MatchboxARM August 06, 2013 04:49PM |
I think I would still argue you get better value with ARM, 32 bits at 48Mhz vs 8 bits/20MHz.
Re: MatchboxARM August 07, 2013 07:37AM |
Re: MatchboxARM August 07, 2013 03:51PM |
Re: MatchboxARM August 07, 2013 08:43PM |
Re: MatchboxARM August 08, 2013 02:37AM |
Re: MatchboxARM August 08, 2013 05:46AM |
I'm tired of the anti-3.3V logic arguments. What does commodity even mean?
What does standard even mean in MOSFETs?
Re: MatchboxARM August 08, 2013 08:25AM |
Re: MatchboxARM August 08, 2013 09:03AM |
That was true in the '80s. It might have been true in the '90s. It wasn't true in the '00s. It's not true now.Quote
It means, many electronic components work only with 5V signals. Especially ones for handling high currents.
The voltage required to switch the MOSFET. That's individual and can be extracted from the data sheet. There are only few which do at 3.3V and even fewer of them can handle 50A and up, which is required to use it for switching the 15A of a heated bed without additional cooling.
Re: MatchboxARM August 08, 2013 01:47PM |
Re: MatchboxARM August 08, 2013 02:17PM |
Re: MatchboxARM August 08, 2013 05:01PM |
Re: MatchboxARM August 08, 2013 07:47PM |
>Quote
> cooling.
