Hello,
I am in process of creating/designing a camcorder mount.
I want to mount a small home use camcorder, and control the pan, tilt, and... hmm. there's one more movement, but not sure how to call it. :p Anyway, so it will have 3 motors, one that spins the hole thing along the Z axis, another one to make the camera look up and down (rotational move along the X axis), and the last one adjusting the level/tilt of the picture (rotational move along the Y axis).
I think I will eventually get a working design for the mount and print the parts with my 3D printer. However, I am not sure what I am going to do for the controller.
I guess I could buy another RAMP1.4 (which is the controller I have on my 3D printer) and modify the firmware a little bit, then write a simple control console program which sends g codes to the controller board via USB.
But I would think that's a bit excessive.... All I need is just to run 3 stepper motors. I don't need any feed backs (no end stops). I obviously am not going to need to power the hot end or heated bed (again no feedback from thermistor). If there's anything else I may want to do with the controller board, is to send those camcorder control signal (forgot its name, sorry) with which I can zoom in/out and turn on/off the camera.
I know this is an Electronics forum for RepRap, so I understand my question may not be entirely appropriate to to ask this question, but then again, it's still related to my 3D printing project :p and I would expect to find a lot of people with knowledge in this area.
Are there any controller board that I can use? Hopefully something simple and won't require too much learning?
