Upgrading motors January 15, 2014 08:51AM |
Re: Upgrading motors January 18, 2014 08:19AM |
Re: Upgrading motors January 18, 2014 10:52AM |
although 3-7V is probably ok.Quote
For this reason, stepper motors rated for 3-5 V and 1-1.5 A are generally recommended, as these motors will perform near their peak torque with a current-limiting stepper controller (such as a Pololu A4988).
Re: Upgrading motors January 18, 2014 10:59AM |
Re: Upgrading motors January 18, 2014 06:08PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Upgrading motors January 19, 2014 09:25AM |
Ohmarinus
I'm using the G3D drivers with a 2.5A Nema17. I have the same motors on my other printer too, but they use the Pololu stepsticks imitation version without a 2nd trimpot for the oscillation.
I notice a huge difference in how the motors behave, but on both printers I've never had any torque problems. The advantage for me was that the motors don't overheat because they can easily take the current. The limiting factor in this case would be the stepper drivers.
Just a little question, why would you want to upgrade your stepper motors? And keep in mind that when you use different Nema types, the size will be different, so this means that the spacing of the bolt-holes is also different
Re: Upgrading motors January 19, 2014 10:49AM |
Re: Upgrading motors January 19, 2014 11:29AM |
Re: Upgrading motors January 20, 2014 09:25AM |
Re: Upgrading motors January 20, 2014 05:11PM |
Re: Upgrading motors January 21, 2014 03:42PM |
