Ok, I've got a problem getting a bootloader on a Sanguino board (the long skinny one) that I've assembled. I've tried a bunch of different things and I think I may have a bad crystal oscillator. Here's essentially where I am now, with way more detail below.
---Question---
How critical is the timing for the compiled sanguino bootloader ATmega_644p.hex for 16Mhz vs 12Mhz crystals? I've ordered more crystals, but until they show up I tried using a 12Mhz crystal that I had, and avrdude still gave rc=-1 when trying to just read the chip. The fuse bits suggest that it just needs >8MHz, right? Is there something special about the way the bootloader works with the timing, or is there something worse wrong with my board?
---More Detail---
Sanguino v1.0 PCB from makerbot, with my own components.
WinXP SP2 with Arduino 0017, WinAVR 20090313, Sanguino software 1.4r1, avrdude 5.6 (Mar 5 09)
16MHz crystal from the local electronics supply (that may be suspect), with two 22pF ceramic disc caps. 12 Mhz crystal from same supply (with the same suspicion)
*3 SEPARATE* ATmega644P chips have been tried
USBtinyISP from
adafruit, built from their PCB and my own components. Verified to work with other tiny2313's as well as the extruder 2.2 board
Brian Dean's parallel ICSP programmer, verified to work with tiny2313's (used it to program the USBtiny chip)
Arduino "miniusb" USB to TTL converter, v3 from
adafruit, tried to run it in bitbang mode based on
this ExMrClean post, with the correct pinouts from the
arduino page and the
FTDI datasheet, including setting the CTS# and RTS# pins in avrdude.conf as negative pins (ie, SCK ~3). Inconclusive: I could never get avrdude to respond other than rc=-1
High Voltage parallel programmer made from a Basic Stamp board of education and the atmega644p datasheet
---Process---
*Chip #1*
Tried burning the Sanguino bootloader using Arduino 0017 and USBtiny: rc=-1
Tried burning the Sanguino bootloader using avrdude with USBtiny the same target chip: rc=-1. Flaky USB connection from USBtiny as a result of using 1W zeners and not 0.5W. Replaced zeners and USB connection issue went away, but still rc=-1.
Tried powering chip from usbtiny and externally for all usbtiny tests. rc=-1
Tried to read chip using avrdude/bsd programmer: rc=-1
Tried using -B <0-40> with avrdude and usbtiny: rc=-1
Tried to use avrdude and usbttl in bitbang mode, with and without -B 4800: rc=-1
Tried to read chip using high voltage basic stamp: sucessfully read and reset fuses, erased chip.
Tried to burn bootloader with USBtiny/avrdude. Tried burning hex, writing lock bits to 0x3F, writing lfuse 0xFF, writing hfuse 0xDC, writing efuse 0xFD in one go, with intent to set lock bits to 0x0F on next command: SUCCESS writing hex, fuses (no flashing debug light tho). Next command to write lock bits gets rc=-1. (note: fuse values from boards.txt for sanguino)
Tried to get HVBasicStamp to read fuses again: all fuses, signature bits set to alternately 0x99 or 0x0A, attempts to reset fuses do not stick.
Tried again to read using avrdude/bsd programmer: rc=-1
Gave up on chip #1
*Chip #2*
Tried to start over by burning bootloader using arduino/usbtiny: rc=-1
Gave up on chip #2
*Chip #3*
Tried to burn bootloader with avrdude/usbtiny by writing hex, lock bit 0x3F, lfuse 0xFF, hfuse 0xDC, efuse 0xFD, lock 0x0F: SUCCESS writing all bits. No blinking debug light. Next avrdude read command rc=-1
Powered Sanguino board via external supply plugged into the wall and scoped the crystal: all I got was a nice clean low amplitude 60Hz wave (from the wall socket, i'm assuming), both in powered and unpowered states. Crystal dead?
Replaced 22pF caps with other ones of same type. rc=-1
Replaced crystal with 12MHz while waiting for replacement 16MHz. rc=-1 (no access to scope while at home).
---AVRDUDE---
Here's the output from avrdude for the Chip #3 program that seemed to work. No change was made to the hardware between commands.
D:\WinAVR\bin>avrdude -c usbtiny -p atmega644p -P usb
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e960a
avrdude: safemode: Fuses OK
avrdude done. Thank you.
D:\WinAVR\bin>avrdude -c usbtiny -p atmega644p -P usb -U flash:w:ATmegaBOOT_644p.hex:i -U lock:w:0x3F:m -U efuse:w:0xFD:
m -U hfuse:w:0xDC:m -U lfuse:w:0xFF:m -U lock:w:0x0F:m 0v
Reading | ################################################## | 100% 0.02s
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "ATmegaBOOT_644p.hex"
avrdude: writing flash (65382 bytes):
Writing | ################################################## | 100% 36.44s
avrdude: 65382 bytes of flash written
avrdude: verifying flash memory against ATmegaBOOT_644p.hex:
avrdude: load data flash data from input file ATmegaBOOT_644p.hex:
avrdude: input file ATmegaBOOT_644p.hex contains 65382 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 34.38s
avrdude: verifying ...
avrdude: 65382 bytes of flash verified
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xFD"
avrdude: writing efuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFD:
avrdude: load data efuse data from input file 0xFD:
avrdude: input file 0xFD contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xDC"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xDC:
avrdude: load data hfuse data from input file 0xDC:
avrdude: input file 0xDC contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0x0F"
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
D:\WinAVR\bin>avrdude -c usbtiny -p atmega644p -P usb -B 12
this check.
D:\WinAVR\bin>avrdude -c usbtiny -p atmega644p -P usb -B 12 -F
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
avrdude: Expected signature for ATMEGA644P is 1E 96 0A
Edited 1 time(s). Last edit at 11/13/2009 11:57PM by toomanyplugs.
