Motherboard v1.2: atmega644 vs atmega644P [solved] November 12, 2009 03:03AM |
#ifndef __AVR_ATmega644P__ #error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu. #endif
C:\Users\reprap\AppData\Local\Temp\build6219.tmp\/RS485.h: In function 'void rs485_tx(byte)': C:\Users\reprap\AppData\Local\Temp\build6219.tmp\/RS485.h:16: error: 'Serial1' was not declared in this scope In function 'void init_serial()': error: 'Serial1' was not declared in this scope In function 'bool read_tool_response(int)':
Re: Motherboard v1.2: atmega664 vs atmega664P November 12, 2009 04:35AM |
Re: Motherboard v1.2: atmega664 vs atmega664P November 12, 2009 11:35AM |
Re: Motherboard v1.2: atmega664 vs atmega664P November 14, 2009 01:43AM |
Re: Motherboard v1.2: atmega664 vs atmega664P November 14, 2009 05:19PM |
Re: Motherboard v1.2: atmega664 vs atmega664P November 15, 2009 06:26PM |
Re: Motherboard v1.2: atmega664 vs atmega664P November 21, 2009 01:47AM |
//start our hardware serial drivers void init_serial() { pinMode(RX_ENABLE_PIN, OUTPUT); pinMode(TX_ENABLE_PIN, OUTPUT); digitalWrite(RX_ENABLE_PIN, LOW); //always listen. Serial.begin(HOST_SERIAL_SPEED); Serial1.begin(SLAVE_SERIAL_SPEED); }
