ATX supply to power RPi / RAMPS / OctoPi March 27, 2014 06:09PM |
Re: ATX supply to power RPi / RAMPS / OctoPi March 27, 2014 08:38PM |
Re: ATX supply to power RPi / RAMPS / OctoPi March 27, 2014 10:21PM |
Many PC PSUs (not all) require a base load on the 5V rail to work properly. Connecting an old CD drive or a 12V light bulb (into the 5V rail, see picture) are well proven methods to get this load.
Wether you need a base load or not has to be tried. If even tiny loads on the 12V rail cause the PSU to turn off, a base load is required. Also, a base load never hurts.
Re: ATX supply to power RPi / RAMPS / OctoPi March 28, 2014 05:27AM |
Re: ATX supply to power RPi / RAMPS / OctoPi March 28, 2014 07:45AM |
Re: ATX supply to power RPi / RAMPS / OctoPi March 28, 2014 10:51AM |
Re: ATX supply to power RPi / RAMPS / OctoPi March 28, 2014 02:27PM |
Re: ATX supply to power RPi / RAMPS / OctoPi March 28, 2014 03:00PM |
Re: ATX supply to power RPi / RAMPS / OctoPi March 28, 2014 03:44PM |
Re: ATX supply to power RPi / RAMPS / OctoPi March 29, 2014 03:41PM |
Re: ATX supply to power RPi / RAMPS / OctoPi March 29, 2014 06:39PM |
Re: ATX supply to power RPi / RAMPS / OctoPi January 07, 2016 04:53PM |
Re: ATX supply to power RPi / RAMPS / OctoPi May 07, 2016 10:01PM |
Re: ATX supply to power RPi / RAMPS / OctoPi August 03, 2016 12:17PM |
Re: ATX supply to power RPi / RAMPS / OctoPi August 03, 2016 02:47PM |
Re: ATX supply to power RPi / RAMPS / OctoPi August 03, 2016 02:48PM |
clydefrog
Hello Guys. I have sucessfully connected and shut down my atx power supply, but I have one problem: my ramps is powered trough USB and the atx. When I switch off the atx with m81, it turns off, but my Ramps has power trough the USB connection from my PC. the problem is: When I disconnect the USb cable, the atx ist switching on for ~1s, and immediatly switching off and the back on and so on. Until the capacitors in the atx are empty, then it stops. What can i do? Is it because of the pull up?
Thanks!
Dominik
Re: ATX supply to power RPi / RAMPS / OctoPi December 05, 2016 01:34PM |
