Rambo 1.2x board
Posted by sbloom67
Rambo 1.2x board
April 08, 2014 10:10AM
So I am getting ready to build my large printer and I want to use 24 volts for large bed , etc.
My question is how much amperage can a Rambo board accept and send out ???
Also, I want to use Nema 23 steppers for x y and z. I see ones rated for 1 amp and higher.
How much power can the Rambo send out per coil ???
Re: Rambo 1.2x board
April 08, 2014 11:06AM
According to the wiki [reprap.org] the rambo has 3 power supplies with the following rating:
  1. Heated Bed, 15A 12-24V (version earlier than 1.1 limted to 14A 16V due to fuse rating, see rambo_development for hacks)
  2. Extruders and fans, 5A 12-24V (fuse can be exchanged for up to 10A capacity) 10V-26V input voltage
  3. Motors, 5A 12-24V (fuse can be exchanged for up to 10A capacity) 10V-26V input voltage
April 08, 2014 11:26AM
I really need to know how much each stepper can handle in Amps so I can make sure I can get the correct Nema motor.
Thanks Steven
April 11, 2014 08:30AM
Rambo uses A4982 drives, datasheet here - [www.farnell.com]
Edited 1 time(s). Last edit at 04/11/2014 08:30AM by tjb1.
