Help replace dead hotend heater (Ohm's Law and Rated Wattage) June 29, 2014 11:45PM |
Re: Help replace dead hotend heater (Ohm's Law and Rated Wattage) June 30, 2014 04:56AM |
True or false? Will it produce a maximum of 1w of heat?
True or false? Will it die if more than 1w goes through it?
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Help replace dead hotend heater (Ohm's Law and Rated Wattage) June 30, 2014 07:44AM |
Re: Help replace dead hotend heater (Ohm's Law and Rated Wattage) July 01, 2014 06:58AM |
NoobMan
If effective dissipation and/or temp is higher than rating, then should expect the life of the resistor to be much shorter.
Re: Help replace dead hotend heater (Ohm's Law and Rated Wattage) July 01, 2014 07:50AM |
Re: Help replace dead hotend heater (Ohm's Law and Rated Wattage) July 02, 2014 06:47AM |
NoobMan
You are right, the general consensus is that so if we heatsink it we increase its rating. I just think the net worth of this is not necesarily predictable.
Re: Help replace dead hotend heater (Ohm's Law and Rated Wattage) July 02, 2014 09:51AM |
Re: Help replace dead hotend heater (Ohm's Law and Rated Wattage) July 02, 2014 11:50AM |
Re: Help replace dead hotend heater (Ohm's Law and Rated Wattage) July 03, 2014 08:20AM |
MRGiacalone2005
I tried with the firmware output at 225 and when I send a print the PSU shuts down again.
Re: Help replace dead hotend heater (Ohm's Law and Rated Wattage) July 03, 2014 02:51PM |
Re: Help replace dead hotend heater (Ohm's Law and Rated Wattage) July 04, 2014 01:08PM |
