Hot End Temperature Not Reading Accurately July 22, 2014 11:53AM |
Re: Hot End Temperature Not Reading Accurately July 23, 2014 07:11AM |
Re: Hot End Temperature Not Reading Accurately July 23, 2014 11:36AM |
NoobMan
The meat thermometer probably does not show correct surface temperature, being round and surface flat etc.
The thermistor table in firmware contains one adc column and one temperature column. The firmware reads the adc value and translates it to temperature by the use of that thermistor table. You can calibrate the thermistor table manually. You can take each row, and from the table that is uploaded in firmware, set the temperature in the row, to trick the system to reach the corresponding adc value. Then you measure that point with a real life temperature tool (preferably a multimeter with a termocouple), and write that real value down for each row. Then you replace the old table temperatures with your own temperatures and do the firmware upload again. And double check etc.
Re: Hot End Temperature Not Reading Accurately July 23, 2014 03:38PM |
Re: Hot End Temperature Not Reading Accurately July 23, 2014 05:09PM |
Re: Hot End Temperature Not Reading Accurately July 23, 2014 05:21PM |
3Dmaker4U
What about the fan? I can't see any in the picture. If you have a general one that blows over the heatcore, that's not actually a good setup.
Did you check that the set screw holding the stainless steel barrel is tight? Eventually, unscrew it, take the barrel out and check if the surfaces are clean and there is nothing impeding the thermal transfer. Make sure both surfaces are clean and smooth.
Re: Hot End Temperature Not Reading Accurately July 23, 2014 08:10PM |
Re: Hot End Temperature Not Reading Accurately July 24, 2014 04:23AM |
Re: Hot End Temperature Not Reading Accurately July 24, 2014 12:45PM |
Cefiar
Where did you get the thermistor that is in the hot end you have? If you can find the correct table for it (or calculate it) then you'll get much better results.
You may find that the calibration is still off (eg: 240 when it's say 200) and that your temp readings are not as accurate as you'd like.
NoobMan
You mentioned that you bought the extruder used. Maybe the guy before used it for abs, and was not fully cleaned, so it needs 240c to melt those abs bits in order to extrude, otherwise at lower temp the abs might block the nozzle orrifice. This could be a plausible scenario or explanation, if it needs a real 240c for extrusion. You mentioned you use black and purple pla, if it would of been clear transparent pla maybe it would of showed some impurities inside. Or you can perhaps try ask the previous owner if it printed abs with it.
Also i would try to give some insulation to hotend. My personal preferred method is to cover the hotend in a high temp silicon. This can be bought at gas stations or auto parts shop and it is "silicon gasket" for motor block or evacuation galleries and it is stable to temps up to 400C and is cheap, and has fairly good adhesion to metal surfaces. It aslo makes some bad smell first time its heated up, but after that it gets cured and its fine and odorless afterwards.
Re: Hot End Temperature Not Reading Accurately July 25, 2014 03:48AM |
Re: Hot End Temperature Not Reading Accurately May 08, 2015 05:58PM |
Re: Hot End Temperature Not Reading Accurately July 22, 2017 05:48PM |
