Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 19, 2014 06:40PM |
dc42
btw I wouldn't choose standard RAMPS or any other 8-bit Arduino electronics to run a delta, because the 8-bit processors barely have enough power for this application. I suggest you choose 32-bit electronics.
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 20, 2014 08:24AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 20, 2014 04:06PM |
vreihenThe RepRapPro Duet board is also 32-bit, but the RepRap firmware does not have Delta support beyond a promise by a forum member here to implement Delta support over the next few months.[/quote
Actually, the promise I made was January, so it's weeks not months. But of course, it's still vapourware until I deliver it! The preparatory work is going well and I expect to have the basic delta support working in 1 to 2 weeks from now. You can track the progress in the 'delta' branch of my RepRapFirmware repository in github.
The Duet supports Ethernet and a web interface. Does the Smoothieboard?
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 20, 2014 07:02PM |
vreihen
The Azteeg X5 Mini is a 32-bit board, runs Smoothieware, and sells for $109 USD the last time that I looked. No complaints with mine on a Delta, and it is a very popular option on the Google Deltabot group.
I am partial to Smoothieware on either the Azteeg X5 Mini or Smoothieboard, since the Delta support is mature and was written by a Delta printer designer.....
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 21, 2014 09:32AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 21, 2014 12:59PM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 21, 2014 01:23PM |
calmasacow
Are you using once of the VIKI LCD? how well does it work? Definatley would like to use one of these I dont really see how you can get along without it to be honest.
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 21, 2014 01:42PM |
dc42
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 22, 2014 03:29AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 13, 2015 01:31AM |
NoobMan
If you fancy DIY, then this may be an option. You have to draw wiring, but will work with any development board of any kind Sort of breadboard style.
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 13, 2015 12:27PM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 13, 2015 01:39PM |
vreihen
I am looking forward to seeing Delta support in RepRapFirmware on the Duet. The lack of Delta support is the only reason why I did not buy a Duet board months ago.....
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 14, 2015 09:00AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 14, 2015 09:04AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 14, 2015 09:31AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 14, 2015 09:48AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 14, 2015 10:02AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? May 15, 2015 10:29AM |
1/128 Microstepping? Does it whine like those DRV8825 at 1/32 does? 1/128 is making me drool here for some stuff but too bad we can't software control these on the fly for corners and certain other things. Now that I really want to see for these printers.Quote
angelo
...DippSwitches MSN1=1 (x2), MSN2=2 (x4) MSN3=3 (x16) for Full 1/2 1/4 1/8 1/16 1/32 1/64 1/128 Microstepping:
[attachment 47110 RADDS_2-Back.jpg]
