Odd warning message from my Duet board
Posted by David J
June 15, 2015 05:55PM
I keep seeing an odd error message when I print a file on my delta:
T0
Error: Macro file tpost0.g not found
I have no idea which code in my file is involved - I only have simple commands in my beginning and end gcode (heater on/off, motors off at the end, and so on).
NB: My delta doesn't use a mechanical probe that needs to be activated and de-activated.
Re: Odd warning message from my Duet board
June 16, 2015 02:34AM
The tpost0.g file is run when you select tool 0. It's needed in multi-extrusion machines. You can either ignore the message, or put an empty tpost0.g file in the /sys folder of the SD card.
June 16, 2015 07:06AM
OK - thanks!
