You may need a different 'die set' (the jaws), as I don't see one that matches the connector terminals you have on that eBay item.
If you look at [
www.elpress.se] and look at page 8, you'll see the type of terminal crimper you need. Look at the pic under "crimp type'. That is how the connector should look when the wire is crimped.
