This case is a combination of some other cases on Thingiverse... designed to increase Duet PCB cooling with a standard squirrel cage blower available on Amazon.
i.imgur.com]
Figured others might want to use this or build off of it:
Design features:
1. FAN!!!!
2. Big vents on top
3. Fan blows about half above and half below Duet PCB
4. Finger Hole for hitting reset button
5. Hole for MicroSD is slightly larger so you can push with finger to remove.
6. Height of case allows the lid to be used with standard Molex connectors.
Designed to work with these fans (12v and 24v)
www.amazon.com]
www.amazon.com]
www.amazon.com]
