New PanelDue touch screen beta firmware - testers wanted November 08, 2015 10:33AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 08, 2015 11:23AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 08, 2015 11:30AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 08, 2015 11:45AM |
o_lampe
The full A-Z keyboard looks good, but is it really a requirement?
Only a few letters are necessary.
You could make the buttons bigger with less letters. ( At least for the 4.3" display )
Just my two cent, I'm using web-control...
-Olaf
Re: New PanelDue touch screen beta firmware - testers wanted November 09, 2015 04:52AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 09, 2015 05:37AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 09, 2015 06:49AM |
filipeCampos
Can i suggest a new feature in the keyboard... add two arrows (up and down). Every time the user send an gcode is saved in memory or better in a file (SD card), this will be the historic of the gcodes send. The arrows up and down are used to navigate in the gcode history.
Re: New PanelDue touch screen beta firmware - testers wanted November 09, 2015 09:25AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 09, 2015 09:36AM |
lolocaledo
What do you think about one another page with jog controls ?
Something like these pictures.
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 09:27AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 09:58AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 10:08AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 10:13AM |
lolocaledo
In my config.g, I have M550 DELTALolo but "My RepRap 1" in the title bar on PanelDue.
It's the same title in the Web interface.
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 10:14AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 10:43AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 11:54AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 03:24PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 04:00PM |
cglass
The 4.3 version runs perfectly. The 5.0 version loads with the screen inverted (easily solved in the setup menu post installation). Changing the keyboard language seems to have no effect except on the selection button.
cglass
I found it easy to navigate and it feels a little more intuitive/logical than the previous firmware version.
cglass
My only request would be a setting to change the number of heaters shown. If I have two heaters and a heated bed, I would like to disable the other two heaters (3 and 4) on the 4.3 and the other four (3, 4, 5 and 6) on the 5.0.
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 04:32PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 10, 2015 08:56PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 11, 2015 11:12AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 13, 2015 08:07PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 14, 2015 02:05AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 14, 2015 11:39AM |
lolocaledo
- in Console messages, there isn't CR (carriage return) so we can't see all the message if the message is long
I'm a fanatic of PanelDue :-)
Re: New PanelDue touch screen beta firmware - testers wanted November 14, 2015 11:53AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 15, 2015 11:29AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 15, 2015 04:14PM |
zombiepantslol
- switch over to the new-style M408 responses - I know it's not trivial to make the necessary adjustments, but these responses already provide everything necessary AFAICS, including the G31 trigger values and chamber heater information (if enabled)
- add an extra "Offline" status to PanelDue indicating when a status response hasn't been received for, say 15 seconds. This would come in handy to see if the UART connection has been interrupted during a print
- (optional) only change the Z probe colour if no print is in progress. this would mimic the behaviour of the web interface
- make the polling interval configurable via the Setup page. The web interface shows changes far more frequently and it would be nice to play a bit with this setting directly via the LCD touchscreen
zombiepantslol
- close the print dialog again when a new file print is started
zombiepantslol
And so far I've found two issues with the PanelDue:
- occasionally the LCD panel remains white after I switch on my printer. if I then switch my printer off and on again, it seems to work nicely again
zombiepantslol
- the print progress bar flickers and I can only see a chunk of it
zombiepantslol
Other than that I'm pretty happy with it - I already have a few more ideas that could be implemented via RepRapFirmware and PanelDue to make the printer fully autonomous (especially via USB OTG), but I really have no idea when I will have time to look at this and if RRF allows this due to the lack of free RAM.
Re: New PanelDue touch screen beta firmware - testers wanted November 16, 2015 02:18PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 16, 2015 06:29PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 17, 2015 11:15AM |
