Re: New PanelDue touch screen beta firmware - testers wanted November 17, 2015 12:09PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 17, 2015 04:42PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 18, 2015 03:22AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 18, 2015 03:44AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 18, 2015 05:50AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 18, 2015 06:51AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 19, 2015 03:08AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 19, 2015 08:03AM |
critical_limit
Have 1.12 installed yesterday night.
On startup after connecting to the duet the bed temeratur is showing "-273" in active °C instead of "0" like the hotend.
Once you tap field it´s switching to "0". After leaving the menue its switching back to -273°C
critical_limit
And in the Macro menue the "German Umlaute" are not shown correctly. Instead of ü, ä, ö there symbols shown.
Re: New PanelDue touch screen beta firmware - testers wanted November 19, 2015 08:09AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 19, 2015 02:12PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 19, 2015 05:13PM |
dc42
Accented characters come out properly in the gcode file list for me. Do they for you? Do macro names work properly in the web interface? I can't think why macro files would be any different from gcode files. However, the files with accented characters on my SD card were uploaded over the web interface. If you write the files to the SD card in a PC, then perhaps the PC was using a different character encoding. The Duet firmware assumes ISO 8859-1.
Re: New PanelDue touch screen beta firmware - testers wanted November 19, 2015 07:22PM |
critical_limit
dc42
Hi David,
all accented characters are not shown on the Panel. Its fine in the web interface and shown correctly. Doesnt matter if I upload it via the web interface or direct to the card. In web Interface all is fine, but on the panel it´s wrong.
I´m using a mac (osx el capitan), but tested it with a PC (windows10) as well. not working on the panel.
By the way... checked the html in web interface and in the head is: meta charset="utf-8"
Any ideas how to correct this on the panel?
Re: New PanelDue touch screen beta firmware - testers wanted November 20, 2015 03:13PM |
dc42
Two suggestions:
1. Can you confirm that you are running my fork of RepRapFirmware, preferably version 1.09k?
2. Please attach one of the problem macro or gcode files so that I can try uploading it to my Duet with the same name.
Re: New PanelDue touch screen beta firmware - testers wanted November 20, 2015 05:06PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 20, 2015 06:13PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 20, 2015 06:41PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 21, 2015 03:02AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 21, 2015 04:48PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 21, 2015 04:55PM |
Re: New PanelDue touch screen beta firmware - testers wanted November 22, 2015 06:05AM |
ormerod168
lolocaledo
- in Console messages, there isn't CR (carriage return) so we can't see all the message if the message is long
Yes , e.g. not able to show firmware version with M115, besides that I love everything about it!
Erik
Re: New PanelDue touch screen beta firmware - testers wanted November 22, 2015 07:19AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 22, 2015 07:45AM |
critical_limit
David,
made a test uploading your file. On Web Interface it´s ok like all other accented characters. On the Panel not. See pics:
[attachment 66368 IMG_0953.jpg][attachment 66369 IMG_0954.jpg]
Re: New PanelDue touch screen beta firmware - testers wanted November 22, 2015 09:02AM |
critical_limit
dc42
Just a thought: what size display are you using? I did my tests using a 4.3 inch display.
Same here. 4.3 display
Re: New PanelDue touch screen beta firmware - testers wanted November 22, 2015 09:27AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 22, 2015 09:39AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 22, 2015 10:28AM |
critical_limit
While you worked on the characters I integrated my webcam stream into Webinterface... ;-)
[attachment 66375 Bildschirmfoto.jpg] [attachment 66376 Bildschirmfoto1.jpg]
Re: New PanelDue touch screen beta firmware - testers wanted November 22, 2015 10:54AM |
Re: New PanelDue touch screen beta firmware - testers wanted November 22, 2015 11:21AM |
critical_limit
You solved it. Loaded your testfile to the macro folder and now it works. Actually I have a print running, but will do other tests after.
But I think you solved it completly.
Big Thanx!!
Re: New PanelDue touch screen beta firmware - testers wanted November 22, 2015 11:38AM |
dc42
Great, but please try the new PanelDue firmware I linked to in my previous post and see if that works with your original macro file.
Re: New PanelDue touch screen beta firmware - testers wanted November 30, 2015 08:46AM |
