RADDS + RepRapFirmware [mini review] November 16, 2015 05:56AM |
Re: RADDS + RepRapFirmware [mini review] November 16, 2015 07:13AM |
Re: RADDS + RepRapFirmware [mini review] November 16, 2015 08:21AM |
filipeCampos
-I using clone arduino due and is work fine, what is the problem you have?
Yes, native USB. I 'm not sure it really slows down the prints, it just looks like it does.Quote
filipeCampos
-About the problem you have with the raspberry, are you using the usb native port? I have made some testing using an raspberry 512mb ram and not found any speed problem.
That's the point. Using other programs, e.g. pronterface, to "run" the print works ok. Using cura to do this doesn't work (for me at least)... (slicing is fine; sending gcode to the printer is not working from cura)Quote
filipeCampos
-About cura: the problem is with the slider or starting the print with cura? I used both sliders cura and slic3r and no problems, but always start and controlled the print using pronterface.
filipeCampos
I have too installed the 128 steppers and i have the same result you have, the motor make almost no noise or vibration.
Something i have noticed too is the temperature of the motors is always very low. Before i have 1/32 steppers and the motors was hot after some hours of printing, but now the are always cold and using the same voltage i have before (+/- 0.9v).
These 1/128 are very impressive...
Re: RADDS + RepRapFirmware [mini review] November 16, 2015 08:43AM |
Re: RADDS + RepRapFirmware [mini review] November 16, 2015 09:02AM |
dc42
If you are driving a modern printer controller board through its native USB port (which is not the same as serial-over-USB e.g. as on Arduino/RAMPS), then you can get better throughput by turning off the "wait for OK after sending each command" in the host program settings. You can do this in most host programs, but I am not sure that you can in Octoprint.
Re: RADDS + RepRapFirmware [mini review] November 16, 2015 07:28PM |
Re: RADDS + RepRapFirmware [mini review] November 17, 2015 03:36AM |
toxuin
A little bit offtopic, but how do you set RAPS128 inverted enable signal?.. When my RADDS powers up my motors become instantly engaged and do a loud THUMP without movement. This can't be right.
M569 P0 S0 R1 ; Drive 0 goes forwards (change to S0 to reverse it) M569 P1 S1 R1 ; Drive 1 goes forwards M569 P2 S1 R1 ; Drive 2 goes forwards M569 P3 S1 R1 ; Drive 3 goes forwards M569 P4 S1 R1 ; Drive 4 goes forwards
Re: RADDS + RepRapFirmware [mini review] November 18, 2015 02:03PM |
Re: RADDS + RepRapFirmware [mini review] November 19, 2015 05:09AM |
