smart controller on RUMBA not working
May 18, 2016 10:06PM
I am installing RUMBA board with a smart controller "12864 LCD Smart Controller Display" .on my 3D printer.
1/
configuration.h file:
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
#define SDSUPPORT // Enable SD Card Support in Hardware Console
2/
u8glib has been installed, sketch compiles and uploads with no issue
3/
Cabling has been checked many times and reversed as a check
Symptoms:
- when the cables are reversed the screen is blue with a buzzing noise
- when the cables are installed per the recommended connection, the display black.
- turning the dial does not affect anything on the display but does flash red LED on RUMBA board
- Repetier can not communicate with the printer while the LCD is connected
- disconnecting the LCD from RUMBA allows Repetier to communicate with the board and control printer
Any thoughts that anyone may have would be greatly appreciated.
Thank you,
Chris
Re: smart controller on RUMBA not working
May 19, 2016 12:28AM
"Repetier can not communicate with the printer while the LCD is connected'
There is a hardware fault somewhere...
Check for solder blobs on the LCD board and on the RUMBA around the EXP1 and EXP2 pins
May 24, 2016 06:45PM
Thank you very much for your feedback Dust.
I checked the boards as thoroughly as possible for solder blobs and everything was clean.
You were correct though, it was a hardware problem.
The sockets on the RUMBA are upside down.
It turns out that I had to invert the connectors of smart controller to board by 180°.
To allow me to invert the connectors 180° I had to remove the alignment bumps on the connectors.
Once the connectors were flipped 180 the display works fine.
Chris
May 25, 2016 05:39AM
Well done on finding that!
I’ve heard of upside down connectors on 2004 lcds before but not on a Rumba
Some of these suppliers are so creative in their stuff ups!
