RUMBA board SD card December 09, 2016 08:38AM |
Re: RUMBA board SD card December 12, 2016 06:38PM |
Re: RUMBA board SD card December 13, 2016 12:13PM |
Re: RUMBA board SD card December 13, 2016 12:19PM |
Re: RUMBA board SD card January 02, 2017 12:25PM |
Re: RUMBA board SD card January 02, 2017 07:05PM |
Re: RUMBA board SD card January 03, 2017 03:43AM |
Re: RUMBA board SD card January 03, 2017 05:11AM |
Re: RUMBA board SD card January 03, 2017 07:21AM |
Of course I did. In the end I tried every possibility but no succes.Quote
Did you remember to cross the ribbon cables so that so that EXP1 on the RUMBA board goes to EXP2 on the display and EXP2 to EXP1?
I'll try it on my ramps board. Yes I have the adapter.Quote
If so then try plugging in the display board to a RAMPS board. You will need the adapter for the RAMPS board.
At least that way if it works then you know that there is something going on with the RUMBA board.
Thanks, I'll try on power supplyQuote
I have also heard that not all Full Graphics boards will work with just USB power.
Mine dose but then when I turn on the power supply it gets noticeably brighter.
For basic function, I have both the RAMPS and RUMBA board using a Full Graphics boards. However on the RUMBA board the SD card dose not work.
It appears that the firmware for both boards uses pin # 53 to enable the SD card. But the RUMBA will not enable the SD card.
I am waiting for parts for the new printer so I will start playing around some more and keep you posted.
Re: RUMBA board SD card January 03, 2017 04:27PM |
Re: RUMBA board SD card January 03, 2017 04:45PM |
Re: RUMBA board SD card January 03, 2017 05:31PM |
Re: RUMBA board SD card January 03, 2017 05:36PM |
Re: RUMBA board SD card January 03, 2017 07:33PM |
Re: RUMBA board SD card January 03, 2017 08:14PM |
Re: RUMBA board SD card January 04, 2017 06:03AM |
Re: RUMBA board SD card January 04, 2017 06:50AM |
Re: RUMBA board SD card January 04, 2017 07:07AM |
Re: RUMBA board SD card January 04, 2017 07:36AM |
Re: RUMBA board SD card January 04, 2017 12:36PM |
Re: RUMBA board SD card January 05, 2017 03:42AM |
Re: RUMBA board SD card January 05, 2017 05:21AM |
Re: RUMBA board SD card January 11, 2017 06:50AM |
Re: RUMBA board SD card January 11, 2017 01:43PM |
Re: RUMBA board SD card January 12, 2017 02:57AM |
Re: RUMBA board SD card January 12, 2017 03:31AM |
Re: RUMBA board SD card January 13, 2017 04:08AM |
Re: RUMBA board SD card January 26, 2017 06:41AM |
Re: RUMBA board SD card January 26, 2017 11:10AM |
