Raspberry
Posted by Emmanuel
Raspberry
May 11, 2011 04:53PM
did you see the raspberry ? [www.raspberrypi.org]
"an ultra-low-cost computer...expected price is $25"
after the little sanguinololu, maybe a little computer to controle the machine ^^
Re: Raspberry
May 14, 2011 09:20AM
I saw that too. It looks cool. I am trying not to get my hopes up too much about the price though. These types of projects always seem to go over budget. Put a real time Linux OS on there and you could run reprap plus all sorts of peripherals off it. Plus the display is your TV (or a pico projector?smiling smiley Doesn't seem to have too much IO though, so you might have to put an IO expander board or something on it before you can run a reprap.
Re: Raspberry
September 13, 2011 08:13AM
There have been quite a few updates recently, check out [www.raspberrypi.org]
They are looking at shipping boards in November, two different models, $25 and $35
In terms of IO, the spec looks a bit tight, but do-able IIRC 16 GPIO pins.
I think it would be an excellent addition to a 3D printer. It would allow you to get the printer on the network, it should have enough processing power to do slicing (though not as quickly as on a gruntier pc), and the HDMI and USB connectivity would allow for funky touchscreen interfaces.
Cheers,
Doug.
Re: Raspberry
September 14, 2011 11:34PM
Or one could download a firmware like SJFW and ditch the PC to printer connection all together. The PC is only needed for the design / slicing / gcode generation.
Charles Gantt.
Build blog [themakersworkbench.com] <---- my personal site
Build worklong [www.thebestcasescenario.com]
Re: Raspberry
January 25, 2012 05:40AM
The Raspberry Pi (model cool smiley is due to be released in the next few days/weeks smileys with beer
I was wondering if anyone had ARM binaries for any of the RepRap host and slicing software?
If they are or they can be compiled then I could see it being an awesome addition to any RepRap setup. I'm thinking hook it up to the electronics via usb, attach to a router via ethernet and power on, then just remotely push files onto it to slice, dice and cook.
My Reprap blog
jds-reprap.blogspot.com
Re: Raspberry
January 25, 2012 07:50AM
I thought most of these were written in Java, so should be platform independent.
It'll be a lot slower on the Pi compared to a modern pc.
Re: Raspberry
January 25, 2012 11:29AM
Good point.
The advantage of the Pi is its about the same size as RAMPS (without the mega), runs off 3.5W, silent and costs about £25 for the full version.
I was planning on buying one as soon as they are out to run xbmc and hopefully another to tinker with.
I just figuired if it could run xmbc and some of the other apps they demo'd it would be too much slower then using a conventional pc.
I suppose I'll have to wait and see.
My Reprap blog
Re: Raspberry
February 02, 2012 04:29PM
Seems like the ultimate use of the Pi would be as a replacement for both the computer and the arduino. Just have a RAMPS like board plug directly into the Pi. Of course that would be a bunch of new code to write, and might not be usefull for any other machine.
Re: Raspberry
February 03, 2012 04:57AM
The trouble is the Raspberry Pi only has a single serial port spare. So you wouldn't have enough i/o ports to directly use RAMPS or any other solution without a micro-controller (well as far as I'm aware).
My Reprap blog
