Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 11, 2018 10:11AM |
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 11, 2018 07:13PM |
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 12, 2018 01:00AM |
Shank man
can you post these files? (board.gen7-arm.h and printer.mendel.h)
I have a couple of these boards up and running and I'll compare the files
to see if anything differs.Its worth a shot..
// Configuration for controller board. #include "config/board.gen7-arm.h" // Configuration for printer board. #include "config/printer.mendel.h"
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 12, 2018 07:21PM |
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 13, 2018 08:15AM |
SysTick->CTRL = SysTick_CTRL_ENABLE_Msk // Enable the ticker. | SysTick_CTRL_TICKINT_Msk // Enable interrupt. | SysTick_CTRL_CLKSOURCE_Msk; // Run at full CPU clock.
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 13, 2018 08:54AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 13, 2018 09:20AM |
Dust
what compiler version on what os are you using?
Linux AMILO-Pi-2550 4.15.0-29-generic #31~16.04.1-Ubuntu SMP Wed Jul 18 10:19:08 UTC 2018 i686 i686 i686 GNU/Linux
Using built-in specs. COLLECT_GCC=arm-none-eabi-gcc COLLECT_LTO_WRAPPER=/usr/bin/../lib/gcc/arm-none-eabi/7.3.1/lto-wrapper Target: arm-none-eabi Configured with: /build/gcc-arm-none-eabi-Ubq5Xp/gcc-arm-none-eabi-7-2018q2/src/gcc/configure --target=arm-none-eabi --prefix=/build/gcc-arm-none-eabi-Ubq5Xp/gcc-arm-none-eabi-7-2018q2/install-native --libexecdir=/build/gcc-arm-none-eabi-Ubq5Xp/gcc-arm-none-eabi-7-2018q2/install-native/lib --infodir=/build/gcc-arm-none-eabi-Ubq5Xp/gcc-arm-none-eabi-7-2018q2/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/build/gcc-arm-none-eabi-Ubq5Xp/gcc-arm-none-eabi-7-2018q2/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/build/gcc-arm-none-eabi-Ubq5Xp/gcc-arm-none-eabi-7-2018q2/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/build/gcc-arm-none-eabi-Ubq5Xp/gcc-arm-none-eabi-7-2018q2/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/build/gcc-arm-none-eabi-Ubq5Xp/gcc-arm-none-eabi-7-2018q2/install-native/arm-none-eabi --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for Arm Embedded Processors 7-2018-q3-update' --with-multilib-list=rmprofile Thread model: single gcc version 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907] (GNU Tools for Arm Embedded Processors 7-2018-q3-update)
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 13, 2018 11:58AM |
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 13, 2018 03:25PM |
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 13, 2018 04:43PM |
Shank man
I installed the latest commit and had no problem connecting with Pronterface running on both Windows & Raspian.
I think that possibly could rule out any bugs?
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 13, 2018 05:11PM |
TheCrazyInventor
Shank man
Could you perhaps upload the .hex file so I can give that a try on my board? Maybe I'm having compiler/linker issues or something like that.
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 13, 2018 05:40PM |
Shank man
sure, if you can tell me where it is or go about making one. I not very savy when it comes to these type of things.
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 13, 2018 08:14PM |
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 14, 2018 04:19AM |
Shank man
Thanks I can't believe I didn't see it the first time. This is the one created from the latest commit.
I did not alter the printer or board files.
I hope this works. I can attach my earlier hex file if need be
Re: Gen 7 2.0 and teacup-arm not working with pronterface or repetier October 14, 2018 05:20AM |
