I'm setting up my 3D printer for 4 nozzle, 4 stepper color print. My setup is Re-ARM+RAMPS 1.5+Marlin 2.0 (debug) in EEB configuration with two additional stepper motors using a motor extender card. T0, T1, T2 (A0-A2) analog inputs as heater temperature sensors work fine. However, none of the other pins labelled as analog input capable work. I've disable the LCD for the pins on that pin cluster.
I set the cold extrusion protection down to 10 deg (default 50) so the motors work at room temperature is the assigned thermistor is working, or a cold extrusion error if the thermistor is not.
What am I missing?
Here is the Re-ARM+RAMPS documentation.
A0 0 // A0 (T0) - (67)
A1 1 // A1 (T1) - (68)
A2 2 // A2 (T2) - (69)
A3 3 // A3 - (63) - J5-3 & AUX-2
A4 4 // A4 - (37) - BUZZER_PIN
A5 5 // A5 - (49) - SD_DETECT_PIN
A6 6 // A6 - ( 0) - RXD0 - J4-4 & AUX-1
A7 7 // A7 - ( 1) - TXD0 - J4-5 & AUX-1
