RAMPS 1.4 MArlin 2.0.9.2 + BTT TMC2208 UART - TMC Connection Error December 20, 2021 10:04PM |
Re: RAMPS 1.4 MArlin 2.0.9.2 + BTT TMC2208 UART - TMC Connection Error December 21, 2021 01:31AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: RAMPS 1.4 MArlin 2.0.9.2 + BTT TMC2208 UART - TMC Connection Error December 21, 2021 07:49PM |
Apologies, I thought that the Rx and Tx pin connections on the Ramps were a likely source of error, as opposed to the rest of the board.Quote
Dust
Bad picture.. cannot see anything
I checked the continuity on the microstep/jumper pins, and they are all connected to their adjacent pin even without the jumper installed. I never would have thought to check that, but I see that the wiki does have a line specifically addressing this issue. Will these permanent connections damage the drivers if I try to use UART?Quote
Dust
One thing to check is some particularly nasty ramps come pcb traces under the micro stepping pins, so even if you remove the jumpers they are still connected.
Check they are really disconnected with a multimeter.
Re: RAMPS 1.4 MArlin 2.0.9.2 + BTT TMC2208 UART - TMC Connection Error December 21, 2021 09:35PM |
Re: RAMPS 1.4 MArlin 2.0.9.2 + BTT TMC2208 UART - TMC Connection Error December 23, 2021 01:07AM |
