gen3 motherboard V1.2 isn't communicating with ReplicatorG September 08, 2011 07:38PM |
Re: gen3 motherboard V1.2 isn't communicating with ReplicatorG September 27, 2011 12:04PM |
[driver name="sanguino3g"] <!-- was reprap5d --> <!-- optional: COM1 --> [rate]38400[/rate] <!-- was 19200 --> [/driver] (note: change all square brackets to < or >, the forum was messing them up)(I changed the driver name and the rate to 38400 to be consistent with an older machines.xml from a previous version of RepG that worked for me, though I can't find any other reference than this depricated version: [code.google.com] I recommend you verify the rate in the motherboard firmware source code if necessary. I think the sanguino chip uses 38400 by default anyway)
Re: gen3 motherboard V1.2 isn't communicating with ReplicatorG September 27, 2011 02:04PM |
#define HOST_SERIAL_SPEED 38400
#define UBRR_VALUE 25Note: UBRR is a calculation based on chip speed and baud rate, etc., see here: [winavr.scienceprog.com]
UBRR=((f_clk/(BaudRate*16))-1) where f_clk – microcontroller clock speed(Hz); BaudRate – communication baud rate.
(16000000/(38400*16))-1 = 25
Re: gen3 motherboard V1.2 isn't communicating with ReplicatorG September 28, 2011 06:01AM |
Re: gen3 motherboard V1.2 isn't communicating with ReplicatorG September 28, 2011 07:01AM |
Re: gen3 motherboard V1.2 isn't communicating with ReplicatorG September 28, 2011 10:44AM |
Re: gen3 motherboard V1.2 isn't communicating with ReplicatorG September 28, 2011 12:02PM |
Re: gen3 motherboard V1.2 isn't communicating with ReplicatorG September 28, 2011 03:06PM |
