Re: MPCNC July 21, 2019 12:46PM |
Shank man
Local store.
Conduit wasn't a problem but the selection of hardware was severely limited.
5/16 Nylocks nuts are sold in packages of 15, Bolts are sold individually. There were no 5/16, 1-1/4" bolts so I had to cut down some 1-1/2" ones. All 28 of them. There is nothing I enjoy more than cutting
down bolts. Being a low grade course threaded bolt made this somewhat easier.
Roberts_Clif
[ I see you are using Slic3r to do some testing, what did you use to generate the Peace sign G-Code.
I have been fumbling with learning to operate EstlCam through the minute delays before it will allow loading saved projects or slicing any G-Code for any project you are currently working on.
Have not actually cut anything Still procrastinating my final printing accessories Power Supply mounting, Ramps and LCD cases ect, though I made EstlCam G-Code for the MPCNC sketch Sena.
Re: MPCNC July 22, 2019 08:11AM |
Re: MPCNC July 22, 2019 08:03PM |
dc42
Duet WiFi and Duet Ethernet are other popular options as the controller for MPCNC. See [forum.duet3d.com] for some posts about this. The TMC2660 stepper drivers can handle more current than stepstick-drivers can, making them suitable to drive Nema 23 motors if the motors are chosen carefully.
I have the Marlin 2.0 Firmware working perfect on my MPCNC if you need any help with it.Quote
Shank man
I couldn't get the pre-configured V1 Engineering Marlin 2.0 firmware to
compile so I reverted back to a older version
I'm going to switch over the firmware from Marlin to something else.
I've heard of Marlin for CNC
Re: MPCNC July 23, 2019 07:47AM |
Roberts_Clif
I will do you one better, here is a sharable link to my Marlin 2.0 MPCNC firmware
Just a reminder That Marlin 2.0 requires a Arduino IDE 1.8.8 or newer or PlatformIO to compile.
Re: MPCNC July 28, 2019 05:38PM |
Roberts_Clif
Thank you Shank man for Posting your progress.
I am still looking for a Control case, the one I found and 3D Printed is in fact a horrible 3D Printing Control case, it is so thin you can virtually see thew it.
And I do do want to waste my time with such a horribly Thin Control case, in fact do not believe it would survive very long and not protect the controller.
I have found some Anwenk 1/4"-20 x 15mm Furniture Screw in Nut Threaded Wood Inserts and have install an placed 32 of the them in the CNC main Deck.
[attachment 112315 MyMPCNC-1.jpg]
Now I can fasten anything with a simple clamp that is 3D Printed or CNC milled using many type of material. First I still want to Find a Controller Case.
One NOTE: Because I decided to make my MPCNC so tall, the power cable on the Dewalt must be carefully positioned or it will cause the Z-Axis too bind on the X or Y max borders.
I decided, I need to get My MPCNC running. So for a quick fix I am going to quickly 3D Print this.
There is a few modification that I believe should be made while the good parts print, I can modify the pieces that want changes on.
[www.thingiverse.com]
Re: MPCNC July 29, 2019 09:44AM |
Re: MPCNC August 04, 2019 10:16PM |
Re: MPCNC August 08, 2019 05:53PM |
Roberts_Clif
Hello again;;
I discovered today that the longer Stepper motor cables I purchased from California.
Are in fact being shipped from mainland china, so it will be quite some time before I see the parts if ever.
How is it that E-Bay continues allow this to happen, as many times as we have all complained this should have stop.
May have to buy spares from somewhere else to be able to finish the MPCNC build.
Re: MPCNC August 18, 2019 07:31PM |
Re: MPCNC September 18, 2019 09:13PM |
Re: MPCNC September 22, 2019 08:49AM |
Re: MPCNC March 21, 2020 03:30PM |
Roberts_Clif
Still procrastinating, have not finished the layout on my controller case. Have all the parts and know how I want them laid out on my case.
Including wiring to the 8 pin mic sockets and plugs, similar to the CR-10 3D Printers.
Still procrastinating testing how to add another stepper motor driver to my ramps 1.6 driver board so I can have a extruder tool for 3D Printing.
And was waiting for warmer weather to test with the Dewalt Dw660 as it is quite loud inside, though I have tested printing a sketch in pencil with a lot of fine detail.
[attachment 114924 Sena.jpg]
Then I want to place a shed not too far from the house where this project can reside, using a OctoPrint w/cam for year around use to build all sorts of projects.
And maybe I am overthinking this, as My 3D Printer has dual Z stepper motors so I could place my Dual Stepper XY in series and have E0 / E1 for 3D Printing.
As long as I wire them to turn in opposite directions as one spins clockwise the other counter clockwise. An do not use Dual End-stops on the XY Axis.
Re: MPCNC March 22, 2020 09:18AM |
Re: MPCNC - New Primo July 31, 2021 01:47PM |
Re: MPCNC May 26, 2022 02:26AM |
