Testing lumina ldd-1000-40-24-rs with dummy load
May 10, 2023 12:46PM
I have purchased a used Lumina LDD-1000-40-24-RS and I would like to test it (using the analog command on PIN 9) to make sure it works correctly before connecting it to the laser module. I would like to ask what load I could connect as a dummy load, so that I can then put a tester set to Ampere in series with it?
Thanks
