I've been trying print v groove bearings to guild along a 12mm shaft. See attached. The bearing is a 608 skate bearing. I just mocked up a steel plate to mount the four bearings on for testing purposes.
The issue is that I can't get the outer surface of the V to run exactly true with the bearing. The as printed part tends to grab as it rolls. I eventually turned the outer V's on a wood lathe but its still not smooth enough. I even strengthened the layers with CA. The material is PLA
Any ideas?
