Just fyi for anyone building the mcwire with pic electronics, I switched the wires doing a complete reverse (as instructed on the stepper wiring page for the pic) and its working fine. There wasn't anything special to wiring "backwards."
On a separate note, I'm still having the same problem with the thermistor temperature not reading correctly. With the correct C3, it reads 10 low at room temperature, and can't go above 65. Messing with C3 allows me to get the requisite temperature for the software to be able to print a part for CAPA, but that's really annoying and certainly an impediment to expanding into different materials. Does anyone have any idea what this could be? I've tried two separate thermistors, both had the exact same behavior. Here's the debug temperature reading, using the correct C3 of 10nF:
Java 3D WARNING : reported GLX version = 1.2
GLX version 1.3 or higher is required
The reported version number may be incorrect. There is a known
ATI driver bug in glXQueryVersion that incorrectly reports the GLX
version as 1.2 when it really is 1.3, so Java 3D will attempt to
run anyway.
DEBUG: Opening port /dev/ttyUSB0 [0.000s/-1208128939786ms]
Experimental: JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
RXTX Warning: Removing stale lock file. /var/lock/LCK..ttyUSB0
Received data packet when expecting ACK
sendMessage error - retrying
DEBUG: CAPA extruder vRefFactor set to 7 [0.543s/543ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [1.198s/655ms]
DEBUG: CAPA extruder vRefFactor set to 8 [1.198s/0ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [1.774s/576ms]
DEBUG: CAPA extruder vRefFactor set to 9 [1.774s/0ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [2.353s/579ms]
DEBUG: CAPA extruder vRefFactor set to 10 [2.353s/0ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [2.922s/569ms]
DEBUG: CAPA extruder vRefFactor set to 11 [2.922s/0ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [3.502s/580ms]
DEBUG: CAPA extruder vRefFactor set to 12 [3.502s/0ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [4.078s/576ms]
DEBUG: CAPA extruder vRefFactor set to 13 [4.079s/1ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [4.661s/582ms]
DEBUG: CAPA extruder vRefFactor set to 14 [4.661s/0ms]
DEBUG: CAPA extruder re-ranging temperature (faster): [5.234s/573ms]
DEBUG: CAPA extruder vRefFactor set to 13 [5.234s/0ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [5.806s/572ms]
DEBUG: CAPA extruder vRefFactor set to 14 [5.806s/0ms]
DEBUG: CAPA extruder re-ranging temperature (faster): [6.381s/575ms]
DEBUG: CAPA extruder vRefFactor set to 13 [6.381s/0ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [6.958s/577ms]
DEBUG: CAPA extruder vRefFactor set to 14 [6.958s/0ms]
DEBUG: CAPA extruder current temp 8.864886064942482 [7.531s/573ms]
DEBUG: CAPA extruder current temp 8.864886064942482 [17.668s/10137ms]
DEBUG: CAPA extruder temperature set to 0.0C, which is not the standard temperature (110.0C). [18.765s/1097ms]
DEBUG: CAPA extruder heater set to 52/59 limit 4/3 [23.069s/4304ms]
DEBUG: CAPA extruder re-ranging temperature (faster): [27.827s/4758ms]
DEBUG: CAPA extruder vRefFactor set to 13 [27.827s/0ms]
DEBUG: CAPA extruder heater set to 52/59 limit 2/1 [27.872s/45ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [28.426s/554ms]
DEBUG: CAPA extruder vRefFactor set to 14 [28.426s/0ms]
DEBUG: CAPA extruder heater set to 52/59 limit 4/3 [28.473s/47ms]
DEBUG: CAPA extruder current temp 10.774553376596828 [29.029s/556ms]
DEBUG: CAPA extruder current temp 14.428999476252727 [39.178s/10149ms]
DEBUG: CAPA extruder current temp 18.55466270270722 [49.327s/10149ms]
DEBUG: CAPA extruder current temp 22.096190244627962 [59.470s/10143ms]
DEBUG: CAPA extruder re-ranging temperature (slower): [69.619s/10149ms]
DEBUG: CAPA extruder vRefFactor set to 15 [69.619s/0ms]
DEBUG: CAPA extruder heater set to 52/59 limit 5/3 [69.667s/48ms]
DEBUG: CAPA extruder current temp 26.333148883345984 [70.223s/556ms]
DEBUG: CAPA extruder current temp 29.56486298400489 [80.363s/10140ms]
DEBUG: CAPA extruder current temp 32.76194777422677 [90.511s/10148ms]
DEBUG: CAPA extruder current temp 36.47928651470983 [100.649s/10138ms]
DEBUG: CAPA extruder current temp 40.10405516305332 [110.791s/10142ms]
DEBUG: CAPA extruder current temp 43.46085934584477 [120.949s/10158ms]
DEBUG: CAPA extruder current temp 46.3220803110018 [131.105s/10156ms]
DEBUG: CAPA extruder current temp 48.431687961497516 [141.250s/10145ms]
DEBUG: CAPA extruder current temp 51.97034898271454 [151.391s/10141ms]
DEBUG: CAPA extruder current temp 53.26823635535561 [161.532s/10141ms]
DEBUG: CAPA extruder current temp 56.07753561685803 [171.670s/10138ms]
DEBUG: CAPA extruder current temp 60.94988790205514 [181.816s/10146ms]
DEBUG: CAPA extruder current temp 62.793388799193906 [191.957s/10141ms]
DEBUG: CAPA extruder current temp 66.90213026302501 [202.093s/10136ms]
DEBUG: CAPA extruder current temp 62.793388799193906 [212.227s/10134ms]
DEBUG: CAPA extruder current temp 62.793388799193906 [222.362s/10135ms]
DEBUG: CAPA extruder current temp 62.793388799193906 [232.497s/10135ms]
DEBUG: CAPA extruder current temp 66.90213026302501 [242.631s/10134ms]
DEBUG: CAPA extruder current temp 62.793388799193906 [252.766s/10135ms]
DEBUG: CAPA extruder current temp 62.793388799193906 [262.906s/10140ms]
DEBUG: CAPA extruder current temp 66.90213026302501 [273.061s/10155ms]
DEBUG: CAPA extruder current temp 62.793388799193906 [283.197s/10136ms]
DEBUG: CAPA extruder current temp 62.793388799193906 [293.353s/10156ms]
Changing C3 to match room temperature (instead of the 9 deg. C it was reading with C3 = 10nF), results in a higher temperature limit, but the same behavior. I have attached a screenshot of my extruder preferences and a picture of my board. Thanks for any help anyone can provide.
