Small Drill Bits
Posted by degroof
Small Drill Bits
June 27, 2008 10:57PM
Found some small drill bits. The set includes 10 bit ranging from 80AWG (0.34mm) to 61AWG (1mm). It's available through Amazon for $10. [www.amazon.com]
Re: Small Drill Bits
June 28, 2008 10:27AM
Looks like Amazon sells two similar but even less expensive sets:
What Do Customers Ultimately Buy After Viewing This Item?
23% buy the item featured on this page
37% buy
20pc MICRO-DRILL INDEX 61-80 - DREMEL compatible - METAL - WOOD - PLASTIC - HSS
[www.amazon.com]
$6.99
(Looks like the plastic case has a sliding cover to dispense one bit at a time. Despite the "Dremel compatible" in the title the drills don't seem to have a 1/8" shank so you need a chuck to use them on a Dremel. You can get the chuck from Amazon for $7.20.)
31% buy
21pc MINI-DRILL Set INDEX 61-80 QUALITY w/Small Aluminum Hand Drill
[www.amazon.com]
$8.99
(This one seems to be the same as above but includes a pin vise to be used as a hand drill)
Micro-Tools.com has a similar wire-gage drill set for $5.70 and a 15-piece metric set (0.3, 0.35, 0.4, 0.45, 0.5, 0.55, 0.6, 0.65, 0.7, 0.75, 0.8, 0.85, 0.9, 0.95, 1.0mm) for $3.45. Another set for the same price covers 1.05mm to 2.0mm.
June 28, 2008 10:51AM
Wow! Thanks for the head's up on Micro-Tools.com. That little $3.45 set is VERY cost effective. Better still they are right up the road from me in Vacaville. Perfect!
March 04, 2012 04:32PM
Could you pls send me the price for 0.55mm and for 0.8mm drills. I'm interested in about 5,000 pieces each.
Many thanks,
Goran
