Driving Two Leadscrews With One Stepper Using a Belt October 25, 2016 11:13PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt October 26, 2016 12:15AM |
Garry Bartsch
This design has the two leadscrews driven by one stepper to eliminate the problems that can occur with driving two z leadscrews each with their own steppers. The leadscrews hang from the top of the printer. Inside the cylindrical housing is a thrust bearing supporting the leadscrew. Radial bearings position the leadscrew left and right [but see point 3 below]. The bottom end of the leadscrews sits in a protector bracket but is free moving.
I have some concerns:
1) Can the single stepper support the x cross member when it's powered off? Or will the weight of the assembly pull down enough to turn the stepper? (The leadscrew is Tr8*8)
Compared to what, two motors driving two screws that get out of sync every time you look at them? It will work fine.Quote
Garry Bartsch
2) Could there be enough play between the belt teeth and the GT2 pulley so that z movements will not be precise enough?
Garry Bartsch
3) Will it be difficult to position the leadscrew centered axially over the leadscrew nut? My concern is the leadscrew isn’t a tight fit inside the two radial bearings (one inside the lower cylindrical housing and one in the upper hosuing) and there might be the tiniest bit of slop. When the belt is tensioned the leadscrew will be pulled tight against the inside of the bearing. The leadscrew nut mounted to the x cross member can move left and right to adjust it's position under the center of the leadscrew along x, BUT it cannot move front and back (y) at all because the leadscrew nut housing is a fixed size. When the belt is tensioned in the way I have drawn it here there will be some rearward pull (y) on the leadscrew. This could pull the leadscrew out of axial alignment with the leadscrew?
Two idler pulleys could be added to the belt path so it would only pull directly to the center of the machine, thus eliminating that problem but I'm wondering if that is even needed?
I'd appreciate comments if this is a good arrangement or should I consider another? Thank you
Re: Driving Two Leadscrews With One Stepper Using a Belt October 26, 2016 12:08PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt October 26, 2016 03:23PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt October 26, 2016 08:18PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt October 26, 2016 08:19PM |
o_lampe
DD
You will wonder, as I do, why anyone messes around with dual motor arrangements
Maybe because you'd need a rigid printer frame to cope with the belt tension. Something I wouldn't dare to try with my cheap acrylic framed Prusa I3...
Re: Driving Two Leadscrews With One Stepper Using a Belt October 26, 2016 08:54PM |
the_digital_dentist
No, not nearly that tight. If you make the belts too tight they wear faster. In the Z axis, it probably won't wear much at all, anyway, but you don't want the tension causing unnecessary loading on the motor, either.
The belt should be just tight enough...
Re: Driving Two Leadscrews With One Stepper Using a Belt October 26, 2016 10:44PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt October 27, 2016 12:36AM |
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 07:45AM |
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 08:19AM |
Garry Bartsch
[attachment 85429 beltpath.png]
This is how I had thought to route the belt so it would pull inwards only. Plus it would give the belt contact with the stepper pulley as Mark advised.
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 04:12PM |
JamesK
Looks good. What size motor are you using for Z?
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 04:14PM |
the_digital_dentist
Great pictures. I can see nicely how you did many things. I WANT layer alignment like you. That is just killer.
Your machine has a heavy belt for Z. Can I expect not to have trouble using 6mm GT2? Or is a heavy belt required?
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 04:53PM |
But if I did as you with larger pulleys on the screws then the smaller stepper would be fine? I'm just learning as I go and relying heavily on experience like yours and others. Your belts are 6mm GT2?
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 05:46PM |
JamesK
Yes again to 6mm GT2 belt. I think it's adequate for the job, but the relatively shallow profile does seem more prone to jumping a tooth than the chunkier belts I've seen. I don't think you will have any problems with the belt path you now have, and given that your frame looks plenty rigid enough to carry adequate belt tension.
JamesK
We'd all like to have layer registration like DD's! Mine can't match that, I think because of the overly flexible (whippy!) 8mm smooth rods in it. The next build will hopefully be a lot more rigid using linear guides.
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 05:55PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 06:57PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 06:59PM |
JamesK
My x and y steppers have the ends supported
Out of interest, how did you arrange that? The shaft on my motors isn't long enough to pass through the pulley and into a bearing.
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 07:16PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 07:26PM |
the_digital_dentist
I think the main problem with over tightening belts is that it can cause the motor or other pulleys to tilt if they aren't mounted very solidly (one of the problems with non metallic printer frames) resulting in the belt teeth engaging the pulley's teeth at an angle. That will wear the belt quickly.
Re: Driving Two Leadscrews With One Stepper Using a Belt October 30, 2016 09:43PM |
the_digital_dentist
I used a 5mm pitch XL belt because I had the 42 tooth pulleys for the screws and the 20 tooth pulley for the motor. In my machine, the X axis weighed about 4-5 kg. I would not have felt comfortable with 6 mm GT2 belt. Maybe 9 or 10 mm would be OK.
the_digital_dentist
I drove NEMA-23 motors with a RAMPS board for a long time. As long as you keep the current within the driver's capabilities you can drive any size motor. The NEMA-23 motors I used were not especially high torque for that size motor and were rated at 2A. I used a small one that delivered about 100 oz-in holding torque which can be done with a NEMA-17 motor, and a couple 130-150 oz-in motors.
Re: Driving Two Leadscrews With One Stepper Using a Belt October 31, 2016 10:37AM |
Garry Bartsch
I'm remembering (maybe): amps are pulled not pushed? Drawing too much current from the driver will fry it? From the above it sounds like I can use a NEMA-17 anyway without overworking it.
Re: Driving Two Leadscrews With One Stepper Using a Belt October 31, 2016 12:31PM |
the_digital_dentist
If they are properly heat sunk (soldered to a large ground plane in a PC, they can deliver more current than it they are not properly heat sunk (plug-in modules).
Re: Driving Two Leadscrews With One Stepper Using a Belt November 07, 2016 12:31PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt November 07, 2016 12:36PM |
dthomas6184
How did you go about picking your belt length? i'm looking to implement a similar 2 screw 1 motor setup myself to drive my bed instead of a cantilever bed setup.
Re: Driving Two Leadscrews With One Stepper Using a Belt November 07, 2016 04:08PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt November 07, 2016 05:45PM |
Re: Driving Two Leadscrews With One Stepper Using a Belt November 07, 2016 06:10PM |
Origamib
I have a similar system rigged up to mine. The stepper can easily be moved left and right to make it tighter, as well as the two central pulleys. This means the belt can be any length (within reason) and then just move the stepper to take up the slack.
Re: Driving Two Leadscrews With One Stepper Using a Belt November 07, 2016 06:13PM |
the_digital_dentist
Draw the thing in CAD, measure the lengths of the straight belt segments, add to that the lengths wrapped around the pulleys. That will get you into the ball-park. Then make the motor or pulleys adjustable to adjust tension. Make sure you pick a belt that's a little longer than you need- you can always take up slack, but there isn't much you can do if the belt is too short.
