Pinch-wheel extruder design July 30, 2008 02:36PM |
Re: Pinch-wheel extruder design July 30, 2008 02:59PM |
Admin Registered: 19 years ago Posts: 1,915 |
Re: Pinch-wheel extruder design July 30, 2008 03:33PM |
Let's say we've got a 1cm diameter drive wheel and the extruder is only 50% efficient. I think this means we'd need a motor with 4.05N*2 * .5cm = 4.05 N*cm of torque - that's not very much.|
Re: Pinch-wheel extruder design July 30, 2008 04:31PM |
Re: Pinch-wheel extruder design July 30, 2008 04:35PM |
Re: Pinch-wheel extruder design July 30, 2008 05:07PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Pinch-wheel extruder design July 30, 2008 05:23PM |
Re: Pinch-wheel extruder design July 30, 2008 05:35PM |
If you think about how brakes on a bike work: you apply the pressure between the cable and the flexible metal tube that contains it. Moving the cable about does not activate the brakes, only a differential force between the cable and the sleeve.Quote
I'm afraid the stiff tube idea may lead to more variability in the extrusion rate as the tube moves around - what advantage would it bring?
Re: Pinch-wheel extruder design July 30, 2008 07:14PM |
Re: Pinch-wheel extruder design July 30, 2008 07:34PM |
Re: Pinch-wheel extruder design July 30, 2008 09:39PM |
Re: Pinch-wheel extruder design July 30, 2008 10:44PM |
