Drylin Linear Guides December 21, 2012 03:27PM |
Re: Drylin Linear Guides December 21, 2012 04:53PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Drylin Linear Guides December 21, 2012 05:57PM |
Re: Drylin Linear Guides December 21, 2012 08:10PM |
Re: Drylin Linear Guides December 21, 2012 09:27PM |
You mean like 1 mm thicker and longer each? Just looked that up. Not only the 100% plastic versions, but also the aluminium encapsuled version are a little bit bigger.Quote
they are bigger than LM8UU
Re: Drylin Linear Guides December 22, 2012 06:29AM |
Re: Drylin Linear Guides December 22, 2012 06:36AM |
I replied to an email from their UK FAE.
Yes they are 1mm bigger all round. That means I can't just drop them in any of my machines to try them. I would have to build a new machine so I didn't pursue it.
Re: Drylin Linear Guides December 22, 2012 05:39PM |
Re: Drylin Linear Guides December 23, 2012 10:19AM |
and that you are having issues with our website
All drylin R linear bearings will have greater clearance than the linear ball bearings. This is a requirement of all plain bearings, not just drylin. In fact, the drylin ribbed design allows a tighter clearance than simple plain bore plastic linear bearings.
To achieve a precision fit with the drylin N rail, choose the pre-tensioned carriage, NW-02-27-P. To have a simple, low cost, adjustable linear system use the WS-10 rail fitted with WJUME-01-10 bearings.
I hope this helps, any problems please email me, [email][email protected][/email] (my email will only be checked every few days over Christmas).
Re: Drylin Linear Guides January 10, 2013 07:02PM |
Re: Drylin Linear Guides January 22, 2013 09:00PM |
Re: Drylin Linear Guides February 03, 2013 06:21AM |
Re: Drylin Linear Guides February 03, 2013 07:25AM |
Re: Drylin Linear Guides February 03, 2013 08:59AM |
Re: Drylin Linear Guides February 03, 2013 10:28AM |
Re: Drylin Linear Guides February 03, 2013 01:32PM |
Re: Drylin Linear Guides February 03, 2013 03:36PM |
Re: Drylin Linear Guides February 03, 2013 04:36PM |
Re: Drylin Linear Guides February 03, 2013 07:11PM |
Re: Drylin Linear Guides February 04, 2013 03:30AM |
Re: Drylin Linear Guides February 04, 2013 07:27AM |
Re: Drylin Linear Guides February 04, 2013 08:59AM |
Re: Drylin Linear Guides February 05, 2013 10:22AM |
Re: Drylin Linear Guides February 05, 2013 10:42AM |
Admin Registered: 16 years ago Posts: 13,895 |
Re: Drylin Linear Guides February 05, 2013 11:16AM |
Re: Drylin Linear Guides February 05, 2013 01:24PM |
Re: Drylin Linear Guides February 05, 2013 02:52PM |
Re: Drylin Linear Guides February 05, 2013 05:20PM |
In fact the new Aluminatus uses only leadscrew and no belts...Quote
uGen
While the super-precise linear rails at first seem like the non plus ultra, this level of precision is just not needed for DIY printers/mills. The other components like timing belts are the limiting factors here.
This is the reason why I was mainly oriented towards plastic linear guides: zero maintenance!Quote
uGen
In the end, I think plastic bearings are quite the nice solution for RepRap. About zero maintenance, no lubrication needed so you won't get yourself all greasy when tinkering and reasonably cheap.
I'm searching not the cheapest solution, but the right compromise between price and quality (with this primarily in mind)Quote
uGen
You might also want to check out the DIY bearing research thread if you want the absolutely cheapest solution compatible with many standard components.
I can only say that I want this big assortment of linear guide just to put them on a shelf in the living roomQuote
VDX
With this sort of stages and others in different sizes ( Linearachsen-Alle.jpg ) I was then developing all sorts of microassembly systems or related stuff (optics, 3D-microvision, grippers, ...)
Re: Drylin Linear Guides February 05, 2013 05:46PM |
Re: Drylin Linear Guides February 05, 2013 05:47PM |
