Re: Drylin Linear Guides February 05, 2013 06:21PM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: Drylin Linear Guides February 05, 2013 06:58PM |
Re: Drylin Linear Guides February 06, 2013 02:03AM |
Re: Drylin Linear Guides February 06, 2013 12:16PM |
Re: Drylin Linear Guides February 06, 2013 03:02PM |
Re: Drylin Linear Guides February 07, 2013 07:52AM |
Re: Drylin Linear Guides February 07, 2013 08:34AM |
Re: Drylin Linear Guides February 08, 2013 08:22AM |
Re: Drylin Linear Guides February 12, 2013 10:03AM |
Re: Drylin Linear Guides February 14, 2013 07:48PM |
Re: Drylin Linear Guides February 15, 2013 03:03AM |
Re: Drylin Linear Guides February 15, 2013 07:35PM |
... you can buy small piezo-monoblocks on rail for around 1 USD each - so yes, one can ...
Re: Drylin Linear Guides February 16, 2013 02:13PM |
Can you read in my mind?Quote
uGen
Oh, in case you wonder about these cracks on the rail
Re: Drylin Linear Guides February 16, 2013 05:27PM |
Re: Drylin Linear Guides February 26, 2013 01:53PM |
Re: Drylin Linear Guides February 26, 2013 04:49PM |
Re: Drylin Linear Guides February 27, 2013 08:16AM |
uGen
Actually, I am a little bit disappointed as I imagined the Igus products would perform better.
Re: Drylin Linear Guides March 04, 2013 05:57AM |
Re: Drylin Linear Guides March 24, 2013 04:01PM |
Re: Drylin Linear Guides March 24, 2013 04:39PM |
Re: Drylin Linear Guides March 25, 2013 02:18PM |
Sure you are right! Steel angles or square tubes are the solution...Quote
uGen
I wouldn't use aluminium as the linear rail as it will wear with the hard steel bearings running on it
This is what I thought too, but I read in some diy cnc forums that aluminium angles wear quickly at the beginning (increasing the contact surface) and then hardens (reducing wear).Quote
uGen
The V-Groove bearings on angles don't seem like a good idea to me since the contact between the bearing and the rail is limited to two points. Wear would start to be noticeable more quickly than with the other set-up. The V-Groove bearings are also more expensive than standard bearings.
I saw it a couple of days ago. I like the idea very much (but it could be used only with delrin wheels I think...), but I was looking for something more available worldwide.Quote
uGen
Speaking about V-Groove: Have you already seen this Kickstarter?
Re: Drylin Linear Guides March 25, 2013 04:35PM |
Also I cannot understand why not to slide the V bearing on the 90° corner of the steel angle...
I like very much your bearing design! What about wear?
Re: Drylin Linear Guides March 27, 2013 07:39AM |
uGen
What I just remembered: I have seen polyurethane coated roller bearings that are used for conveyor belts or so. The polyurethane is quite hard while it shouldn't damage aluminium.
Re: Drylin Linear Guides March 31, 2013 04:58AM |
Re: Drylin Linear Guides February 16, 2015 01:23PM |
Re: Drylin Linear Guides February 17, 2015 02:03PM |
moameen
Hi guys, so has anyone used the Drylin guides for their printer and can comment on wear etc?
Re: Drylin Linear Guides February 20, 2015 02:00AM |
Pointy
moameen
I have been using them on my Ormerod and they are working well. I have only printed a couple of kilos of PLA though, since I fitted them last year.
I have the same bed setup as shown in this photo in this thread. I also have the AWMP-12 aluminium shaft and RJUM-01-12 bearing on the X Axis. The main reason I changed was due to the fact my printer is not in an ideal place in my workshop, which is quite damp, and the supplied bearings were starting to corrode.
Regards,
Les
