3 axis CNC from instructables parts question
December 30, 2008 02:15PM
Hi I seen the 3 axis CNC machine in instructables. It seemed interesting now the premade parts on reprap made sence. Now does the arduino and motordrivers software and such work with this project also?
It would seem this put together could be the seed of the rerap...
Parts of the darwin were machined.
This CNC machine could do it.
That would also allow for PCB board cutting right?
I am mostly interested in PCBs.
Re: 3 axis CNC from instructables parts question
December 31, 2008 12:20AM
I believe you are referencing what is referred to on here as a McWire to honor the guy who came up with the orginal design.
In RepRap sense is refered to as a RepStrap that you use to manufactor parts to build a Darwin for Additive manufacturing with a plastic extruder.
Since the McWire was designed for very light milling you can do some very light CNC work with it; though the tool chain that everyone is focusing on here is not for CNC.
However to do even light CNC you need the motion control and this group has made very rapid strides towards reliable electronics that are relatively easy to assemble.
My guess is that in the next month or two there will be a single board Sanguino motherboard kit that you simply plug all the boards that you build from online store kits together and that will take care of most the electronics.
Most people would like to do light milling and various members are experimenting with it inbetween trying to prefect the plastic extrusion process.
December 31, 2008 12:54AM
NOT! A reprstrap is any machine that you can build that will let you produce parts for a Reprap machine. A Darwin is a Reprap machine, not THE reprap machines. Reprap machines are machines that can reproduce themselves to an extent.
NOT SO. Tommelise 2.0 does both light milling AND plastics printing.
> easy to assemble.
Good luck on that.
> process.
No again. Some of us are concentrating on milling and letting other people do the extrusion work.
Hell, there are no rules here - we're trying to accomplish something.
Opportunity is missed by most people because it is dressed in overalls and looks like work.
Thomas A. Edison
December 31, 2008 02:50PM
Forrest Higgs Wrote:
> that
> for
> with
> plastics printing.
> motion
> strides
> relatively
> > easy to assemble.
> build
> take
> Good luck on that.
> extrusion
> > process.
Hi Forrest
Didn't mean to offend or make lite of the work that you have done in milling.
From everthing I had read on here you have been a great contributor.
Have your seen this post on the Sanguino RepRap motherboard?
[blog.reprap.org]
Anyway was trying to give a new member a general orientation based on how he had found us; as he had posted in number of area's on here.
I wasn't trying to lay a rule but I guess you have been descibed as the exeception to the rule a number of times(grin)?
