1) Maybe. I check all over the place, Mcmaster carr, fastenall, MSC direct, ebay, local hardware store.
2) those are 608 bearings, so those should work for the 2 608's
3) I think they still need to be fabricated. Ask Vik.
4) www.vxb.com Buy them in 100 ct quantities and share with someone.
5) See #1. Given that M4 and #8 are dimensionally identical for clearance holes, this should work. A little small, but close. [
www.mcmaster.com]
6) Makerbot is probably as cheap as you're going to get, but I'm not certain if it's standard footprint. [
www.kelinginc.net] has some, but I haven't done the unit conversion to see if its got enough torque. Otherwise anaheim will be your option.
