assist bowden with second small stepper January 31, 2014 12:53PM |
Re: assist bowden with second small stepper January 31, 2014 02:09PM |
Re: assist bowden with second small stepper February 01, 2014 12:01AM |
Re: assist bowden with second small stepper February 01, 2014 09:52AM |
Re: assist bowden with second small stepper February 01, 2014 02:15PM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: assist bowden with second small stepper February 01, 2014 08:23PM |
Re: assist bowden with second small stepper February 02, 2014 04:23PM |
nechaus
I dont think it will help that much, Why add dual motors when you can just use one and dual hobbed bolts?
one nema motor is certainly strong enough
And to me it seems that 2x NEMA17 would work better because like I explained, they can pull together and minimize wear & tear because the contact surface can be made much bigger.|
Re: assist bowden with second small stepper February 03, 2014 02:45PM |
Re: assist bowden with second small stepper February 04, 2014 02:08PM |
Re: assist bowden with second small stepper February 08, 2014 04:22AM |
Re: assist bowden with second small stepper February 09, 2014 08:44PM |
Ohmarinus
I would just do 2x Nema 17 just like with the Z-axis. You can hook up two stepper motors to one driver and have them push and pull the filament working together. In my fantasy it would be that you replace the idler with the 2nd stepper motor, so instead of the filament having a filament driver on one side and a bearing on the other side, the filament is sandwiched inbetween two stepper motors that both spin the filament in the same direction.
The only advantage I see in this way of driving the filament, would be that the teeth gripping in the filament are on both sides, thus almost encapsulating the filament instead of grinding it just on one side. This will not be ideal with gears that are made with M3/M4/M5 threadmakers because it will cause the filament to twist continuously even more than when using only one.
Re: assist bowden with second small stepper February 09, 2014 10:35PM |
Re: assist bowden with second small stepper February 10, 2014 09:10AM |
Re: assist bowden with second small stepper February 10, 2014 06:25PM |
