Teflon coated smooth rod?
March 13, 2014 09:32PM
Has anyone experimented with teflon coated smooth rod? I got a shop locally that does teflon coating and am curious to try it.
Re: Teflon coated smooth rod?
March 14, 2014 11:01AM
What type of bearing/bushing would you be using on such a rod? I'd think any type of conventioanl bearing utilizing balls or a rolling metalic surface would quickly destroy any type of teflon coating. A teflon sleeved bearing or bushing might be suitable.
A2
March 15, 2014 08:03AM
What type of Teflon coating, with ceramic?
I've specified a Teflon coating the type used on frying pans for fusion welding, and thermoforming.
I wouldn't use it in a bearing application, it would just flake off.
The coating is sprayed on, and is typically bumpy.
[www2.dupont.com]
hb2
July 02, 2014 11:10PM
The dry teflon lube is good for indoor use.
A2
July 02, 2014 11:45PM
OP has described a coating, not a lubrication.
There are Teflon impregnated aluminum rods. But a Teflon spray coating with steel ball bearings riding over it would fail very fast. It would also be hard to adjust for proper bearing tension, without the bearings slicing into the coating.
hb2
July 03, 2014 01:34AM
For light moving parts,sliding bearing and non metal material is also applicable.
July 13, 2014 11:31PM
8mm OD x 6mm ID PTFE/FEP tubing + 6mm OD steel rod perhaps?
July 21, 2014 05:20AM
I'm using teflon coated slide bearings (sorry for german link): [cgi.ebay.de]
I just use some printed PLA lm8uu adapters to fit them correctly.
Grüße
Marco
Thingiverse
