Help with cantilevered printer design April 15, 2014 12:08PM |
Re: Help with cantilevered printer design April 15, 2014 12:40PM |
Re: Help with cantilevered printer design April 15, 2014 01:22PM |
Re: Help with cantilevered printer design April 15, 2014 02:20PM |
cozmicray
Really -- your arm is going to hold up 5 pounds of extruder?
Re: Help with cantilevered printer design April 16, 2014 12:46AM |
Re: Help with cantilevered printer design April 16, 2014 11:36AM |
Re: Help with cantilevered printer design April 16, 2014 11:51AM |
Re: Help with cantilevered printer design April 16, 2014 04:51PM |
Re: Help with cantilevered printer design April 16, 2014 04:58PM |
Re: Help with cantilevered printer design April 16, 2014 05:53PM |
A2
Per Du7pLaI.png pic, rotate your X and Z axis 90 degrees.
You want an I-beam configuration on your X axis, (like in this pic Fi30oFF.png).
Rotating the Z axis 90 degrees will increase the moment rigidity of the X axis, and it will allow you to add a 3rd bearing to the X axis to increase rigidity.
Re: Help with cantilevered printer design April 16, 2014 07:59PM |
Re: Help with cantilevered printer design April 17, 2014 01:11AM |
A2
That's correct.
Adding a 3rd bearing to the X, and Y axes would be an improvement.
Why only one linear slide on the Y axis?
You can also increase the spacing between the linear slides on all axes to increase rigidity, but you are limited by your build volume.
Re: Help with cantilevered printer design April 17, 2014 02:00AM |
aEx155
I figured a moving carriage would be less mass than moving the rods (Printrbot simple or Smartrap)
Re: Help with cantilevered printer design April 17, 2014 02:11AM |
A2
For the Y axis second rail it's a follower, meaning all it has to do is support a cantilevered mass.
Re: Help with cantilevered printer design April 17, 2014 02:54AM |
Re: Help with cantilevered printer design April 17, 2014 05:15AM |
A2
I think you can get away with one rail, but it's better to have two.
Re: Help with cantilevered printer design April 17, 2014 06:18AM |
Re: Help with cantilevered printer design April 17, 2014 01:32PM |
A2
The makergear linear bearing looks to be the same size.
Q:
are you copying the MakerGear printer,
are you raising/lowering the Y axis,
are you adding a gantry support,
why are you creating your own design?
Re: Help with cantilevered printer design April 17, 2014 02:23PM |
Re: Help with cantilevered printer design April 17, 2014 03:01PM |
nicholas.seward
I am about to make a suggestion and it won't sound like a smart change but it is. Trust me.
Flip the x rail upside down. Mount the carriage statically and have the rail be dynamic (assuming the rail is light enough). This eliminates edge sag worries by keeping the carriage directly under the cantilever. In theory even if you are at one extreme or the other and the end of the rail is sagging, the height above the carriage will be unaffected.
Additionally, I have concerns about how rigid your frame will be. What do you think about using wood? Is laser cutting an option for you?
Re: Help with cantilevered printer design April 17, 2014 03:51PM |
Re: Help with cantilevered printer design April 17, 2014 05:18PM |
Re: Help with cantilevered printer design April 17, 2014 09:33PM |
A2
A few design ideas to consider:
You only need 3 bearings on the Z axis, triangulate them.
I would prefer a belt on the Z axis, but the stepper might not have enough torque to move the overhanging gantry, you will have to do the math.
The idler pulley on the end of the X axis looks like it's cantilevered out too much, i.e. it might creep over time, reduce the height to a minimum.
The pulley bracket also needs to be redesigned to resist twisting (torsion).
I would align the center of the pulley with one of the metal guides, this will transfer the force to the metal rod.
Radius all the things.
Re: Help with cantilevered printer design April 17, 2014 11:22PM |
Re: Help with cantilevered printer design April 17, 2014 11:26PM |
Re: Help with cantilevered printer design April 18, 2014 12:28AM |
Re: Help with cantilevered printer design April 18, 2014 01:17AM |
Re: Help with cantilevered printer design April 18, 2014 02:35AM |
Re: Help with cantilevered printer design April 18, 2014 03:18AM |
Re: Help with cantilevered printer design April 23, 2014 06:19PM |
