Re: Help with cantilevered printer design April 24, 2014 04:55PM |
Re: Help with cantilevered printer design April 25, 2014 12:47AM |
Re: Help with cantilevered printer design April 25, 2014 03:49PM |
A2
You might be able to use only one LM bearing on each of the shafts of the X-axis, and increase the X-axis length, depends on the fit up.
If you switch the hot end to the other side to avoid the Z-axis lead screw you also might be able to increase your X-axis print window.
X-axis end bracket looks good.
Re: Help with cantilevered printer design April 25, 2014 07:09PM |
Re: Help with cantilevered printer design May 12, 2014 06:12AM |
Re: Help with cantilevered printer design May 14, 2014 12:43AM |
Re: Help with cantilevered printer design May 15, 2014 01:07AM |
nicholas.seward
I would like to see more rigidity for the z rods. Think the x and y are good to go. It will be fun to see this come to life.
