Long Linear Motion, Best Choice? April 28, 2014 05:18PM |
Re: Long Linear Motion, Best Choice? April 28, 2014 10:10PM |
Re: Long Linear Motion, Best Choice? April 29, 2014 12:45AM |
Re: Long Linear Motion, Best Choice? April 29, 2014 02:18AM |
Re: Long Linear Motion, Best Choice? April 29, 2014 02:43AM |
Re: Long Linear Motion, Best Choice? April 29, 2014 07:48AM |
Re: Long Linear Motion, Best Choice? April 29, 2014 08:40AM |
Re: Long Linear Motion, Best Choice? April 29, 2014 10:01AM |
that's the main problem when you make a dual purpose machine you can never get optimal out of both. I myself and many people have attached extruders to routers and although they work it's not optimal. Obviously you're going to need some pretty strong motors as things are going to get heavy but the real fly in the ointment is the steps per millimeter needed for high-speed and high acceleration for good prints is not good for a router and vice versa. Have you looked in the CNC zone they have a lot of routers that have been builtQuote
MrDoctorDIV
It's going to be a 3D printer/CNC in one, so by saying it's more CNC size more or less proves my purpose.
I can afford those massively priced rails from Misumi.. but I would really rather not spend that much if I can acheive the same thing for less.
I plan to use half the bed [about 800X350mm full size] for printing and the full bed for faster machinable materials in CNC.
My mechanics are going to be that of Makerbot/Solidoodle, I knew that before I really started designing it. Interchangeable heads are also in the plans, switching between direct and bowden [and CNC] for different material and mechanical requirements based on what the customer wants.
I've also got steel reinforced GT2 belts, so stretch will be less* so a factor.
Supported rails seems to be the most popular for strength at distance, but that's also a lot of added weight on the moving X carriage.
Re: Long Linear Motion, Best Choice? April 29, 2014 11:17AM |
Re: Long Linear Motion, Best Choice? April 29, 2014 11:32AM |
Re: Long Linear Motion, Best Choice? April 29, 2014 12:14PM |
Re: Long Linear Motion, Best Choice? April 29, 2014 12:53PM |
Re: Long Linear Motion, Best Choice? April 29, 2014 01:28PM |
Oh trust me, I don't get something simply because of price. Before I started designing I told myself skimping out on anything was not an option. The whole point of this build to make it as solid and reliable and powerful as needed and extra.Quote
BoByS
More money you invest - better results you will get.
Re: Long Linear Motion, Best Choice? April 30, 2014 03:11PM |
Re: Long Linear Motion, Best Choice? April 30, 2014 03:25PM |
Re: Long Linear Motion, Best Choice? April 30, 2014 04:39PM |
Re: Long Linear Motion, Best Choice? April 30, 2014 05:31PM |
Re: Long Linear Motion, Best Choice? April 30, 2014 10:07PM |
Re: Long Linear Motion, Best Choice? May 01, 2014 05:05AM |
cnc dick
A car bumper that would take over two weeks 24 hours a day I don't think that's a good idea. With the standard electronics using Nema 23's rated at about an amp and a half should be around 170 ounce inch or so quite a bit more than the nema 17 because of the mechanical advantage of the size of the motor. Still may not be powerful enough depends on how large and how heavy you make it. I would suggest you guys Cut the size down a little bit most professional FDM printers are not even as large as you people are talking about maximum that I might even think about would be 24" x 24" x 24"
Re: Long Linear Motion, Best Choice? May 01, 2014 09:37AM |
Re: Long Linear Motion, Best Choice? May 02, 2014 02:51PM |
Re: Long Linear Motion, Best Choice? May 02, 2014 03:14PM |
FFM or FDM just is not the right method to make a car bumper it is just too large. Offhand I don't really know of any even professional machine that can do one. Maybe some of the largest jet type resin printers out there might. What you're talking is in the $400,000 range. Possibly machining a master plug Or buck out of wood or plastic and then using a vacuum forming machineQuote
pontifex500
And there is no solution for solving the warping problem???Even if I leave smaller nozzle and layer heihgt,make the heated chamber and I let it print more then 2 weeks???
(I cant make it with smaller parts and then gluing pieces together because bumpers would not be hard enough and elastic enough to pass minimum technical needs for car registration)
Re: Long Linear Motion, Best Choice? May 02, 2014 04:16PM |
Re: Long Linear Motion, Best Choice? May 02, 2014 04:20PM |
cnc dick
pontifex500
I know about that method,my friend works that way on his job everyday,but we want to avoid that method or any other method and use 3D printer for making parts.
As we calculated if we would make 3D printer that would print good parts we would save allot of time,effort and material.(Even if it would took 2 weeks or more to print such large parts)
I will buy smaller printer no matter what and I will try to play with it a little bit so any advice is more than wellcome.
If nothing else I will have a printer that will be able to print small plastic parts for car interior or similar.
Edited 1 time(s). Last edit at 05/02/2014 04:21PM by pontifex500.
