I make a mcWire repstrap (http://reprap.org/bin/view/Main/McWire_Cartesian_Bot_1_2), after that I mounted makerbot mk4 (http://wiki.makerbot.com/plastruder-mk4).
So modify machines.xml adding:
machine
name McWire reprap /name
geometry type="cartesian"
axis id="x" length="80" maxfeedrate="1210" scale="400"/
axis id="y" length="220" maxfeedrate="210" scale="400"/
axis id="z" length="60" maxfeedrate="210" scale="400"/
/geometry
tools
tool name="Pinch Wheel Extruder v1.1" type="extruder" material="abs" motor="true" floodcoolant="false" mistcoolant="false" fan="true" valve="false" collet="false" heater="true"/
/tools
clamps /clamps
driver name="sanguino3g"
rate 38400 /rate
parity 8 /parity
debuglevel 0 /debuglevel
/driver
warmup
/warmup
cooldown
(Turn off steppers after a build.)
M18
/cooldown
/machine
When I use replicatorg control panel all go right, 10mm move axis real 10mm, extruder is ok.
But when I run a G-code... there are some differences between move and 2d, for example the zig-zag base is unusable.
May you help me?
Thanks in advance.
v.
