Heatbed vs 3d printer size June 13, 2014 03:02PM |
Re: Heatbed vs 3d printer size June 13, 2014 03:52PM |
Re: Heatbed vs 3d printer size June 13, 2014 04:44PM |
jbernardis
I started out with a prusa that had a 200x200 bed. I've since rebuilt it to a different design that also has a 200x200 bed, and I have designed and built a second printer that has, you guessed it, a 200x200 bed.
I think the 200x200 size just came about because of the size of the frame that can be built without moving up to sturdier parts - like 10mm bars and such. It has evolved into a "de-facto" standard. The main factors affecting bed size are frame size (as I've already said) and the ability to attain and the necessary temperature and to consistently maintain that temperature. The larger the bed, the higher the amperage needed to ready the necessary temps, so this starts to affect the power supply and, possibly, the controller board.
Re: Heatbed vs 3d printer size June 13, 2014 08:11PM |
Re: Heatbed vs 3d printer size June 13, 2014 11:31PM |
Re: Heatbed vs 3d printer size June 24, 2014 04:17PM |
Re: Heatbed vs 3d printer size June 25, 2014 06:59AM |
Re: Heatbed vs 3d printer size June 25, 2014 01:54PM |
Damonh
I've read this thread. Currently I am building the tantillus t-slot variation. I want to go to a 200mm x 200mm build area. I real new at this so bear with me.
I've been trying to figure out the lengths to cut the I have 2000mm of extruded aluminum and calculate I can get 8x 250mm lengths for the horizontal sections. If I understand correctly, since the bed will be on the z-axis 250mm x 250mm should be fine for XY axis and still give me the overall 200mm x 200mm desired build area?
Additionally I will be putting the electronics in a space below with the build area with a covered top. There will also be an additional cooling fan in that space.
Thanks
Re: Heatbed vs 3d printer size June 25, 2014 01:56PM |
the_digital_dentist
Putting the electronics under the printbed sounds like a good way to keep the printer small, but you might want to reconsider. You are making a pretty big printbed, so I assume you are going to want to make big prints. If you try to make big prints with ABS and you don't enclose the printer your big prints are going to delaminate even as they are printing. I suggest that you enclose the printer and make sure the electronics are outside the enclosure. The electronics can still be located under the printer. I would also try to design it so that the X, Y, and Z axis drive motors are outside the thermal enclosure. That way everything stays cool except the print, the printbed, and the extruder.
