It uses three 623zz bearings for each corner of the carriage, each bearing at 120degrees from the other. There's a video at the end which shows half the carriage running along one 8mm smooth rod.
The important thing is, it feels slippery no matter what angle you pull at it, it isn't affected by skew in the way that the traditional linear bearings are.
It's only a prototype obviously, I'm amazed it printed, fit together and worked at all to be honest. The video is awful and doesn't really show it's good points. I've also put the scad file on
thingiverse in case you want to have a play. I'm just starting to get the hang of OpenSCAD, but it's not as parameterised as I'd like.
youtube of it
here
